rwk226
- Ryan
- May 11, 2021
- 23
- 570
- 640
- Senatobia, Mississippi
- 2015 BMW 535xi N55
- Build Thread
- Link
- Vehicle Showcase
Update 9Update 8
Total Tuned Time: 6 Months
Tuned Miles Driven: 7,800 miles (37,800 miles total)
Tunes used: Current: Phearable 1.5R (Previous: Ktuner Stage 0; Phearable 1.5; Dual 21/18/15 tune w/ Quick Adjustments)
Fuel Used: Shell, Circle K, or Mapco (at Mapco I put 1 gallon of e85 in).
Related Mods: K&N Air Filter, Mishimoto Induction Hose.
Problems/Issues: Zero.
Experience notes: Car still is amazing. I daily drive in Map 1 (w/ Eco on when wet), and that's still enough to cause my front tires to break loose if throttle isn't modulated right (any acceleration over 1500rpm when roads are any level of wet causes traction loss thanks to cheap tires). Map 2 causes tires to chirp a little, and Map 3 causes tires to squeal. When you want the car to be refined, it is very much refined. When you want to go fast, you can go fast.
With all that said, If you're on the fence about tuning whether it be because of reliability or because the power increase appears negligible on the non-Si 1.5ts, buy a Ktuner anyways. Reliability is not a concern if you perform regular maintenance and upkeep on your car / not abuse it, and there is a very much noticeable bump in power, not to mention the enhancements made for refinement and top end performance on Phearable's 1.5 and 1.5R tunes. TSP is also good from what I've heard.
Total Tuned Time: 6 Months 3 1/2 weeks
Tuned Miles Driven: 8,800 miles (38,800 miles total)
Tunes used: Current: Phearable 1.5R w/ Turbo Ramp and Throttle set to Highest (Previous: Ktuner Stage 0; Phearable 1.5; Dual 21/18/15 tune w/ Quick Adjustments)
Fuel Used: 93 Octane (Occasionally 1gal e85).
Experience Notes: Did an oil change just shy of 6,000 miles, cleaned out my air filter (not really dirty), adjusted my intake hose, and re-flashed Phearable 1.5R w/ Quick Adjustments set to their highest level. I notice a slight difference from before but nothing game changing. Car still runs smoothly, I run in Eco mode 90% of the time and manage low-mid 30mpg a tank (usually 280-300 miles a fill up), primarily running in Map 1 as it's more than enough for how I drive. BBG is set to 18PSI I believe, may lower it to help with traction. Otherwise, really happy I chose a Civic. 7 months into ownership and loving it.
