What is more reliable for the long term 2.0L vs 1.5L Turbo
Which do you think is more reliable with regular oil changes?
  • Total voters
    128
MJeed
Jeed
Toronto, ON
None
Hi Civic owners,
I'm looking to purchase my first Honda. I have done a lot of reading on a few different Honda forums to determine what I want to buy and am leaning towards the 2017 EX model in Canada as it has a 2.0L NA engine. I am a bit hesitant to get the turbo with the oil dilution scare. I know Honda has released an update that "resolves" the issue but some people are still dealing with strong gas smell in their oil.
I want to drive this car until it can't no more; like the good old civics and corollas. My previous car (my dad's) was an '06 Toyota Matrix and it is currently above 600k km and its still going. I am very strict and diligent when it comes to oil changes.
Side note: My work is about 10km away and it gets cold here in Toronto.
Do you guys think the 2.0L is "more" reliable for the long run compared to the 1.5T?
Jeffers
Jeffers
Long Beach, CA
2020 Si Coupe purchased on 11-24-19
'600k km' For that kind of long term reliability, and if that's the main criteria.
I'd say NA with multiport injection beats turbocharged with direct injection.
When it comes to driving a car until it can't no more.
jred721
James
Northern Virginia
'20 Accord Sport
No debate, 2.0 is more robust since it's from the K-series family of engines, it'll be bulletproof. For the average consumer though, I wouldn't necessarily pick the 2.0 over the 1.5 solely because of reliability but if you're planning on running this car to the ground then 2.0 all the way.
REBELXSi
Señor Member
If I was thinking about my car strictly in terms of an appliance, I'd get the 2.0. Less complications should ultimately mean more reliability long term.
Alphaskoom
David
DFW, Texas
2020 Civic Coupe Sport
in the long haul yes, 2.0 is more reliable.. less moving parts to break, means its more reliable. plus with port injection, it'll keep your intake valves cleaner longer too, that's the main reason i picked the 2.0 over the 1.5 in both Si and non Si configurations.
of course it will mainly depend on how you drive it and how well you keep up with it, these super small engines with turbochargers, pushing out as much power as they can is still relatively new from most manufacturers. Only time will tell.
civicmanic
2016 Civic Touring ; 2020 CR-V Sport(wife)
In that rust belt the rest of the car will fall apart before the engine will imo. If this is a car you're going to have to live with for ~15 years, test drive them and pick what you like best. I can't see you picking the 2.0L after driving both.
civicmanic
more reliable, and will last longer, no oil dilution issues
I've never had oil dilution issues with my '16, and my work is less than 10 minutes away. And it's covered under free extended warranty anyway.
Gruber
Mark
TN
Anyone ever said that an engine without the turbo and without Direct Injection is less reliable?
Are these technologies implemented to improve reliability as the reliability of NA port injected engines was ever questionable? Is there anything in the current NA PI engines that would prevent them from lasting as long as they used to?
The answer to all these questions is NO, so why would anyone even ask the above question? The answer is the 2.0L is what you are looking for, and you have no reason to even think about DI turbo.
Longevity: 2.0NA > 1.5T
Performance: 1.5T > 2.0NA
That's not to say the 1.5T isn't going to hold up for the long haul but the 2.0NA has proven rock solid for quite some time.
On the other hand, I don't keep my cars for 150,000 miles, so I'm confident my 1.5T will do just fine.
civicmanic
who cares if its covered under warranty?
why take the chance?
Because the civic is a MUCH better car to drive with the 1.5t. The warranty is free so no biggie. And as you can see by the vehicles I own, I put my money where my mouth is!
NotSerious
Me
GreatWhiteNorthEh
2018CivicLXSedanCVT
The 2.0 liter K motor has been around for a very long time and is known to be VERY durable. Even in the 8th gen SI where the motor was built into a higher state of tune, the motor could last well over 200,000 miles.
The 1.5 liter motor comes from the subcompact "Fit" with a turbo charger mated to it to make enough power to propel the bigger and heavier Civic. The turbo makes the smaller engine work harder and in theory, will not last as long.
Unless you do a lot of "highway miles", 150,000 miles seems to be the limit before most cars start costing more than they are worth to keep on the road. The transmission, aircon, exhaust, suspension, steering all wear out before the engines do on most modern cars. So, whether the 2.0 liter motor lasts 250,000 miles and the 1.5 liter lasts only 175,000 miles is moot because the rest of the car only lasts 150,000 miles.
If you buy new and keep good care of the car, you should expect about 150,000 miles or 250,000 km out of a Civic no matter which one you get (You can often get much more if you do a lot of "highway miles").
If you are buying used however, the 1.5 liter is much more likely to have performance mods to it. These performance mods and the type of drivers who mod their cars do tend to shorten the life of the car. If you are buying used, I strongly recommend the 2.0 liter. Especially if you are getting a CVT. A turbo-charged motor with performance mods combined with a CVT is a recipe for durability issues.
