Even if boost pressure is not increased in sport mode, throttle sensitivity will still be increased a bit.@Two Step Performance so on TSP 1 map 3 was normal mode 19psi and sport mode bumped the boost. With TSP1+ it is saying normal mode in map 3 is 26psi right of the bat?! And then what does putting in sport mode do? Same psi?? What’s the difference between Normal and Sport in map 3 exactly??
I understand the boost levels are the same in map 1. I was asking about map 3. TSP1 was 19/custom boost (normal/sport) now TSP1+ is 26/???Actually on TSP1 the boost pressure in map 1 is consistent across normal and sport mode. Even if boost pressure is not increased in sport mode, throttle sensitivity will still be increased a bit.
It says right above you and on the product page, 26 PSI in normal and sport. It's the same amount of boost.I understand the boost levels are the same in map 1. I was asking about map 3. TSP1 was 19/custom boost (normal/sport) now TSP1+ is 26/???
I've never eyeballed it. I just put in a gallon of e85 and fill the rest of it with 91 no matter what the gas level is and have never had any issues and knock control always stays at 0.49id assume if youre under half a tank just put a gallon of e in and then fill the rest with 91. it should mix it up enough
for me it's always 1.5 gallons near empty and rest 91 chevronI've never eyeballed it. I just put in a gallon of e85 and fill the rest of it with 91 no matter what the gas level is and have never had any issues and knock control always stays at 0.49
Thanks for clarifying. It does indeed target 26psi in normal and sport mode.I understand the boost levels are the same in map 1. I was asking about map 3. TSP1 was 19/custom boost (normal/sport) now TSP1+ is 26/???
Correct.Don't have an Si but sport mode I assume triggers adaptive dampers and maybe throttle response.
This should work fine but I would not go higher than 1.5 gallons of E85 without a flex fuel kit.for me it's always 1.5 gallons near empty and rest 91 chevron
Hello, I have the TSP stage 1 tune. I mostly drive in map 2. My question is, are there any changes made to the the 19.5 and/or 21 psi tunes, or are the changes mostly to the high boost tune on map 3?Thanks for clarifying. It does indeed target 26psi in normal and sport mode.
Correct.
Yes, there are numerous other changes across all boost pressure levels.Hello, I have the TSP stage 1 tune. I mostly drive in map 2. My question is, are there any changes made to the the 19.5 and/or 21 psi tunes, or are the changes mostly to the high boost tune on map 3?
Great, thank you so much for clarifying. I'll most likely be upgrading! I also really appreciate the increased warm idle speed-that's something I'm sure many of us with upgraded mounts or inserts were looking for.Yes, there are numerous other changes across all boost pressure levels.
I'll cycle between 1-1.5for me it's always 1.5 gallons near empty and rest 91 chevron
I'll try this out.I'll cycle between 1-1.5
let us know how it isJust got my tune file, will flash later, coincidentally i have to get gas today too
