AdamSI
- Adam
- Jun 13, 2020
- 70
- 30
- rohnert park
- 2018 civic si coupe
MAP has there tune unlocked so you can do boost by gear or change the boost target tables. im running 18psi under 5,000rpm then past that 21psi. havent had a issue and i drive pretty hardIs everyone here on the stock clutch using both of these tunes? I’m leaning towards MAP over TSP because of the high tq numbers hurting the stock clutch so soon. Not sure if TSP stage 1 will let my clutch last longer. I mainly commute on the highway for work, but I heard limiting boost by gear on 5th and 6th to 10psi is good for highway. I’m sure driving habits make a difference in the wear and tear of the stock clutch as well, but I wanted to hear you from you guys with the tune on a stock clutch.
