I haven’t looked at fuel pump duty at all. I kinda have a feeling I’m close to maxing it though. I have a solution for this too so stay tuned. No it’s not that Hondata fuel system junk either. I’m running 91 cause California lolHave you logged the fuel pump duty cycle and fuel pressures? I'm assuming you're running 93.
Meth or 100 octane?I haven’t looked at fuel pump duty at all. I kinda have a feeling I’m close to maxing it though. I have a solution for this too so stay tuned. No it’s not that Hondata fuel system junk either. I’m running 91 cause California lol
Neither for now. I want to try my luck with 91 first. I’ll be upgrading my in tank fuel pump with something that flows 100% more than stock. Should be plug and play too. I’m considering running ethanol as well.Meth or 100 octane?
I'm on Hondata's E25 tune and can tell you that the factory fuel pump is maxed at peak torque and fuel pressure drops a little. Not enough to throw CEL. I've reduced the air charge limit to reduce overloading the fuel pump.Neither for now. I want to try my luck with 91 first. I’ll be upgrading my in tank fuel pump with something that flows 100% more than stock. Should be plug and play too. I’m considering running ethanol as well.
Well I’ll just go out and say it.I'm on Hondata's E25 tune and can tell you that the factory fuel pump is maxed at peak torque and fuel pressure drops a little. Not enough to throw CEL. I've reduced the air charge limit to reduce overloading the fuel pump.
I came across that pump last week. Hadn't heard too much about it, but looks solid. Just a little cheaper than Hondata's kit lol.Well I’ll just go out and say it.
The pump is made by Deatschwerks. They have aN in tank fuel pump kit ready to go for the FK8. Roughly around 200 bucks. I picked up the 300c kit. Pump should be good enough for E85 but the next limiting factor would be injectors which they’re working on.
End verdict: buy the RV6 suspension goodies. They work and they’re on the HPD cars for a reason
I still daily my car so I decided to do the rear first. Goal was to have more consistent alignments on track. I was getting toe shifts under braking which caused the rear to squirm. Sway bar helped with getting the car to rotate. I currently have it on the middle setting and find that it’s perfect for me currently.Can you please list the RV6 components you added?
Checked out RV6’s website and it looks like they have (9) offerings listed.
Wallet can’t take it much longer, heh.
Thanks man
Not really noticeable unless you look under the carThanks for the great update on both the radiator and especially the RV6 components. How “noticable” are the lower control arms from the rear of the vehicle since they are red?
Are you running the in-tank fuel pump right now? Does that require changing anything on the tune? Also, I'd be interested if just replacing the fuel pump will add any extra fuel or if it's still limited by the injectors etc.Well I’ll just go out and say it.
The pump is made by Deatschwerks. They have an in tank fuel pump kit ready to go for the FK8. Roughly around 200 bucks. I picked up the 300c kit. Pump should be good enough for E85 but the next limiting factor would be injectors which they’re working on.
I haven’t encountered any issues with the stock fueling on my setup. It’s only when going to ethanol I think. The DW pump should just be a drop in nothing extra necessary. I’ll consult with my tuner to see if we can do anything with the extra headroom now. I haven’t installed mine yetAre you running the in-tank fuel pump right now? Does that require changing anything on the tune? Also, I'd be interested if just replacing the fuel pump will add any extra fuel or if it's still limited by the injectors etc.
The factory high pressure fuel pump is another limitation. Is there a solution to replace that?
