DIY OIL Change Reference Civic Type R
akadic
Jacksonville, FL
(sold) CTR 1722
I did, drove it around the block with the 5 quarts in, let it settle for 2+ hours, still reading high.
alvav
Leonidas
Naxos, Greece
2018 Civic Type R, 2019 Acura NSX
Uh, not sure about the defective dipstick comment. Running a car with too much oil can be as damaging (or more) than running it with low oil. If you ran the car (hopefully not hard) and it's still reading high, I would definitely take some out. Trust the dipstick. Did you change oil and filter or just oil?
akadic
Jacksonville, FL
(sold) CTR 1722
The orange part on the dipstick is really poorly designed, makes it hard to read. Didn't run hard, just drove around the block. I did let some out, now I am between the two holes. Still doesn't makes sense as I poured less than capacity.
EnjoyDriving
Minnesota
2018 CW FK8
Could it be the oil dilution problem??
amurciano
Aaron
Fort Lauderdale, Florida, USA
2019 Honda Civic Type R FK8
Anyone have the oem filter part #, thanks. Thanks all for the tips and shared experiences. I’ve confirmed oem filter to have leaked some but dried up @ 4K miles. What in the world was going on at Honda.
Part # 15400-PLM-A02
Careful buying these off Amazon, some people say they are knock offs. Stick to genuine honda online store (which charge a lot of shipping unless you buy 6 or 30 packs) or see if your local dealership sells you them. I would recommend a fumoto valve and then you never have to worry about drain plug washer.
blitz
Virginia
2019 Civic Type R
I agree with your comment about awareness on purchasing knock-off Honda filters online. Luckily, I have not experienced this. When I’m unable to buy the part at my local Honda dealership, I’ll purchase from Hondapartsnow.com . Everything I have ordered from this site has been prompt, packed in the original factory packaging, and been exactly what I ordered.
BoostedDreams
Heisenburg
South East Florida
2019 Type R, 2006 Mazda 6
Nice write up. I change my oil every 3k miles with Mobil 1 fully synthetic oil. I also have a Fumoto oil drain valve installed so I don’t have to retorque the oil drain bolt every time and risk damaging the aluminum threads on the oil pan. I try to avoid mechanics by all means because most of them are just doing it for the money and can care less about the customers car.
Do you still need to use a crush washer when installing the fumoto valve? I noticed it comes with some soft blue type washer.
blitz
Virginia
2019 Civic Type R
Use a new crush washer (M14 OEM) for the Fumoto valve, and torque to 18 ft-lbs.
BoostedDreams
Heisenburg
South East Florida
Along with the soft washer they supply? From the transmission side would it be, Crush Washer, Fumoto washer, Fumoto Valve?
blitz
Virginia
2019 Civic Type R
Yes, use the supplied crush washer, if it is provided from the valve manufacturer. My Fumoto valve did not have a supplied washer, so I used a new one (OEM) used for the OEM drain bolt.
Do not use two crush washers.
fatherpain
Tom
My experience with the Superstik is it does read the level really well, but doesn’t snap in place like the OEM.
It also stands taller and looks a little funny. I went to OEM, however I use the Superstik to verify proper level when I change the oil.
Some in depth photos and write up here if interested:
https://www.civicx.com/forum/threads/fatherpain’s-2018-type-r.42379/post-748571
https://www.civicx.com/forum/threads/fatherpain’s-2018-type-r.42379/post-757148
I'm thinking about purchasing a SuperStik dipstick where reading the oil level is MUCH easier.
NapalmEnema
Unless the fumito valve is different than OEM - I believe torque spec for the drainbolt is 30ft lbs. I know this because I accidentally did 20ft lbs on my last oilchange and have a nice oil sheen under my car and some slop stains on my garage to remind me -
30 ft lbs you moron - is what I tell myself going forward.
blitz
Virginia
2019 Civic Type R
I was following Fumoto’s support FAQ, and the team states 18 ft-lbs. for the 106 Series valves for the Civic.
Reference post (How much should I torque my Fumoto valve?) -https://help.fumotooildrainvalve.co...393-How-much-should-I-torque-my-Fumoto-valve-
I think the valve material might be less dense than the iron bolt, so it does not need to be as tight to create a good seal. The site says that over-torquing “will add pressure to the adapter.”
As a precaution, the operator can perform a visual inspection after a week and tighten the valve more if oil is seen leaking.
