What exactly did you use ?I measured exact amount I've drained which was 1.9ish qt and put back the same amount of oil. The only difference was that I used Amsoil MTF....and yes, it really makes a difference!!!
What viscosity or type of amsoil MTF did you use ? Also where did you buy it ?What i used where?
https://www.amsoil.com/shop/by-prod.../manual-synchromesh-transmission-fluid-5w-30/What viscosity or type of amsoil MTF did you use ? Also where did you buy it ?
I grew up in LA, you can go to the beach in the middle of December! In fact it's an unusually cold 76 degrees right nowThanks for the advice. I work sales at my dealer so I trust the Service Director to get it done for me. Even if the job is super easy and there are plenty of DIY guides everywhere, I am not confident enough to just do this my first time working on a car.
From reading your posts, California doesn’t really hit 35 degrees, ever, so 100% amsoil should be fine, right? Even then, I tend to always warm up my vehicle for 5 minutes before driving.
4k miles for oil changeThank you very much Tenshi. I just got my Si today, and I'll be doing this at probably 1000 miles, then again at 5000 miles. When do you recommend I do my first oil change? 600 miles?
4k? That seems like a lot. The manual says not to drive it hard the first 600 miles. I was thinking maybe changing it at 600 to get rid of some of the pieces of metal? Why do you say 4k? Sorry, still a noob with this car and any NEW car.4k miles for oil change
I was planning on using this but reading that link it says not for limited slip which the Si has.
I would not use it at all then. I'm going to stick with Honda Genuine MTF but even before that I'll call the dealership and ask to see if they have a special MTF for this vehicle or if it's the regular MTF.I was planning on using this but reading that link it says not for limited slip which the Si has.
Thoughts?
“Replaces Honda Genuine MTF fluid for manual transaxles and Texaco MTX fluid. Not for use in engines, hypoid rear axles, limited-slip or wet-clutch applications.”
Looks like this was brought up and covered in another thread: https://www.civicx.com/threads/my-shiny-new-knob-update-on-last-page-hd-pics.16950/page-4I was planning on using this but reading that link it says not for limited slip which the Si has.
Thoughts?
If anyone was worries like me, there is no need. I contacted Amsoil and they sent back this response.
"Thank you for contacting AMSOIL with your question. The Manual Synchromesh Transmission Fluid covers the specifications for your transmission so it will be fine to use. The note about not using in limited slip applications is referring to not using it in differentials or hypoid gears.
If you have any other questions, feel free to contact us."
I will be swapping out my MTF now, because to me, the shifts occasionally feel notchy.
