Rear clunking endlinks
alao01
Santa Barbara, CA
2016 Honda Civic Ex-L
I just replaced the nuts on the rear swaybar endlinks but in the beginning I didn't know I had to use an allen wrench to stop it from spinning, so I just used a wrench by hand on one end and it rotated a little but obviously it went back in reverse. I did this a few times.
After tightening it the correct way, it seemed fine and no noise was apparent driving on bad roads like before. Although now when making right turns onto an inclined driveway, it makes a loud clunking sound almost like something was overtighened.
For reference, my sway bar does seem off center on the right a inch or so, but the sound seems to be coming from the same endlink I worked on. Is it possible I could've messed the endlink up and does it need to be a certain orientation? I did just order a new endlink just in case and it'll arrive tomorrow.
JT Si
Place
Car
Is this an aftermarket away bar? I think with ones like the whiteline without locator rings people were having clunking issues due to it shifting to one side.
I think the solution is to buy the whiteline locator rings or fashion your own rings/collars.
I bought a progress bar specifically because it already had locator rings on it.
alao01
alao01
Santa Barbara, CA
Yes whiteline sway bar and accord endlinks.
Where can I find the locator rings?
JT Si
Place
Car
I'm fairly confident that either you still haven't tightened the end links enough on the control arm or sway bar ends or you need the locator rings.
alao01
alao01
Santa Barbara, CA
I tightened it by hand and it wouldn't budge more nor could I shake it around. The only time it makes noise is when I make a right turn onto an inclined driveway and not over any other types of bumps or potholes. But if you think its still loose, I'll look at it again and maybe swap out with the new endlink. Maybe its the sway bar now and not the link?
alao01
alao01
Santa Barbara, CA
Another thing to mention if it could a possibility is the nut that I replaced it with is a 15mm but it seems to fit the exact same as the original 14mm it replaced, which I still have.
JT Si
Place
Car
https://www.summitracing.com/parts/whl-kll122?seid=srese1
You can see them here. They aren't anything special, it's just a set of clamps that screw onto the bar to locate it against the bushings. If you want to save $28+shipping you could probably fabricate something that will accomplish the same thing with some help from ye olde local hardware store.
alao01
alao01
Santa Barbara, CA
Ok I'll look into these. Have you tried them before?
JT Si
Place
Car
No, like I said I got a Progress bar because it had locator rings built into it. If you search the forum you can find some threads about the whiteline bars and these rings.
WF19
Mark
North Las Vegas, NV
2020 Civic Si sedan Aegean Blue Metallic; 2003 Pontiac Vibe (just sold)
I seem to remember that the locator rings were needed for the front whiteline sway bar. Haven't had any problems with my rear bar, but I did also use the Accord endlinks.
alao01
alao01
Santa Barbara, CA
I can see the swaybar is off center on the right side because of the grease, do I need to loosen the swaybar bracket and realign and then put on the lateral locks or will it realign itself if I only put the locks on?
JT Si
Place
Car
You should be able to push it by hand with a little grunt to recenter it. It needs to be centered before you put the rings on.
alao01
alao01
Santa Barbara, CA
Ok i'll try that. My rings should arrive this wednesday. Tightened up both endlinks, still clunking so we'll see how it goes.
KOIVUN1
Steve
Chicago
2020 Si CBP
I had the whiteline 22mm rsb, clunked for about 6 months. tried two different endlinks, extra grease, everything. then i just took a three foot breaker bar and stood on the end to tighten the nut. did the trick for me
alao01
alao01
Santa Barbara, CA
How were you able to reach it from that angle and stand on it? Lol or was the bar adjustable on the end? Because its a tight fit in that space...
