team3d
- Aug 15, 2016
- 32
- 511
- 296
- los angeles
- 2016 civic lx
Do not run an aftermarket crank pulley without a harmonic balancer. Your bearings will not last as long
that is false information.
inline 4 engine do not have harmonic balancer, we have crank pulley.
harmonic balancer are mostly found in the crossplane v8Your anecdotal experience is near worthless. The OEM spends 10s of millions each year to put a harmonic damper one engine. Just because you in an opposed motor, low RPM, application (less harmonics) did not fail the engine, does not mean that crank harmonics fail bearings and the more stress the engine is on, and in inline engines, and with steel crank applications (this engine), especially with aluminum block (less harmonic dampening), a silly cheapo pulley will not contribute a quick failure of the bearings. Want to save weight, but a molly flywheel. Only a fool would fit a cheapo pulley on a street driven engine. Put it this way you warranty will be TOAST on any engine issue.. nuff said.
Now if you are talking an expensive billet HARMONIC damper... well it is a 20,000+ thousand dollar car. By all means.
inline 4 engine do not have harmonic balancer.
great video on how factory pulley can fail....
if you google crank pulley fail, all you see is oem pulley split into 2pcs...
here are some examples of factory racing pulley...
