Anti lag-update
BlackedoutFC1
BlackedoutFC1
Virginia
2017 Civic SI Sedan
Hi Guys! Glad you're eager to get started with the new features.
"Anti-lag" only works at a standstill above the Minimum RPM value since it's meant for launch control only. The Ignition Target should be something negative in order to build boost. A value of 0 will disable the feature. Start small (-5 for instance) and work up to what builds the amount of boost you want off the line. I will be adding this info to the help as well.
Is there a reason knock count is happening when shifting gears?
kshawn
Matthew
Maine
2017 Civic SI
You know now that I think of it.. are you viewing the knock count from the V2 unit? Or within ktuner. I've noticed before that my K count in ktuner will sometimes register but I've never seen it go up on the V2 unit, with the laptop plugged in I'll see it tho.
The V2 units firmware was updated along with the ktuner software update. I'm going to try and turn off anti lag and see if I can replicate.
kshawn
Matthew
Maine
2017 Civic SI
BlackedoutFC1
BlackedoutFC1
Virginia
2017 Civic SI Sedan
It was showing up on the v2
kshawn
Matthew
Maine
2017 Civic SI
Darky
Darcy
SW Ontario
2017 Civic SI Coupe
Knock count wasn't displaying on the v2 properly since the last firmware update. It was fixed with this new v2 firmware.
Knock count always logged in data properly tho.
@KTuner if I'm wrong please correct me
BlackedoutFC1
BlackedoutFC1
Virginia
2017 Civic SI Sedan
If that' the case I'm curious why I'm getting knock. 93 octane and knock control at 49ish. Base map. Shouldnt get knock right?
kshawn
Matthew
Maine
2017 Civic SI
A few knocks here and there arnt bad. I belive that the sensor is very sensitive and thoes counts arnt actual knocks.
kshawn
Matthew
Maine
2017 Civic SI
This was my working theory is well :hmm:
KTuner
J.R.
Chandler, Arizona
www.KTuner.com
2017 Si
Knock count was fixed with the firmware update. It did work on some older versions, but was broken, so depending what version you were on you may have seen it work before. Knock control is a better indicator of what's going on than knock count is. If you're at .49 you're clearly doing just fine.
Darky
Darcy
SW Ontario
2017 Civic SI Coupe
My 8th gen knocked like a motha. It's an audible ping ping...ping..ping.
...it also burned oil and ate timing chains for dinner..
Edit_ knocked on 87 that is. 91 it was fine
kshawn
Matthew
Maine
2017 Civic SI
Well damn
Faduzer
OH
2017 Civic Si Sedan
Anyone gotten more in depth on ALS? I have mine set up at -4.0 @ 3500 but its not building much boost? Idk what is considered safe. Im sure there is a low setting where it's relatively harmless? Maybe where I'm at? Maybe a little higher?
BlackedoutFC1
BlackedoutFC1
Virginia
2017 Civic SI Sedan
im at -7.0 and same. not much boost is being built up.
Faduzer
OH
2017 Civic Si Sedan
How much are you building and where do you have launch control, recovery, and anti lag set?
Any experience with ALS? how did you decide on your settings?
