BlackedoutFC1
- Jun 7, 2017
- 34
- 156
- 121
- Virginia
- 2017 Civic SI Sedan
- Vehicle Showcase
- #16
Is there a reason knock count is happening when shifting gears?Hi Guys! Glad you're eager to get started with the new features.
"Anti-lag" only works at a standstill above the Minimum RPM value since it's meant for launch control only. The Ignition Target should be something negative in order to build boost. A value of 0 will disable the feature. Start small (-5 for instance) and work up to what builds the amount of boost you want off the line. I will be adding this info to the help as well.
