OEM BBK: Acura RL 4 piston brake calipers
fenix-silver
Central PA
2019 Si
For those w/ Si's who are following this, does anyone know what the piston area is on the stock 2 piston calipers? With the stock Si rotors being larger than this RL/350z option, I'd be curious to see how the piston sizes compare since the RL pistons need to be larger in order to end up w/ similar braking force as the stock Si setup.
Averia
Arco, ID
2018 Civic Si Sedan
The stock Si rotors are 12.3 in. The 350z rotors for the RL caliper setup are 12.76 in. The Rogue Front Rotors are 12.56 in. If there is a BBK combo that has smaller rotors than stock I don't think they have been included in this thread.
fenix-silver
Central PA
2019 Si
Gotcha! Could have sworn that I read that the stock rotors were larger than the 350z ones, but guess I was mistaken. Appreciate the response!
Jakupdoesnt
Jacob
Civic Hatchback Sport
I have yet to find anyone here on these forums installing Acura RL 4 piston calipers in the front. So, I figured I would make a post about my thought process in going with this option.
I tend to get wordy once I sit in front of a keyboard so here is the TL;DR. 4 piston Acura RL calipers fit on my FK7 Sport with the fastbrakes adapter kit and 12.8" 350Z Brembo rotors. I have confirmed fitment behind the two sets of wheels I have for the car; Evo8 Enkeis (17x8 +38) and Spoon CR93 (17x8.5 +45). They seem to work well so far. However, I have only subjected them to the pad bed in process and some grandpa driving around town. It cost me $375 in hardware.
Please excuse my squat form. Boris would be disappointed.
Now to get wordy.
I began researching brake upgrades for this car after running the full straightaway for the first time at Miller Motorsports Park. It's well known that the original brakes on these Civics really aren't up to the task of multiple laps on a road course, even with race pads and high temp fluid. After one season of HPDE my original calipers were going to need rebuilding or replacing. They were very discolored and the piston boot was reduced to atoms. While a proper performance BBK would almost surely offer the best braking performance, they are very spendy and I do not have any intentions of taking this car back to the track as my CRX project is nearing completion. So I was looking for something to split the difference between refreshing the stock setup and ballin' out on a BBK.
Naturally, the first prospect I considered were FK2/8 Brembos. However, they are still quite expensive and I couldn't find information about how I would actually make them work in regards to mounting the caliper and which rotor to use (re-drill CTR rotors?) I also wanted to retain the use of my 17 inch wheels. I believe Acura TL-S Brembos with appropriate rotors would work - like on Civic 8s and 9s etc - and fit under 17 inch wheels. However, these require some permanent modification to the knuckle and proved difficult to find in the local pick-n-pull yards due to only being on specific TL models. I have read some posts about the Hyundai Genesis Brembos with appropriate rotors fitting, but also requiring 18 inch wheels. Additionally, they are designed to be rear mounted but it doesn't seem like anyone cares about that. The leading and trailing pistons are the same diameter anyway. DC5R Brembos are also designed to be rear mounted AND have staggered piston diameters, which makes them a big no-no for forcing them to work backwards.
Then I came across the RL caliper. These are designed to be front mounted, although they also have equal sized leading and trailing pistons anyway. They are on ALL 2005-12 Acura RL models which makes them very easy to find at the junkyard. The brake master cylinder piston diameter on the FK7 is the same size as the RL, which is especially convenient considering the RL BMC won't bolt up to the FK7 booster. Fastbrakes.com makes an adapter kit, which comes with shiny new bolts and crush washers by the way, to make use of these calipers with 350Z Brembo front rotors. I did not have to trim or bend my dust cover making this an easily reversible modification. The best part is that I'll get to retain the use of my 17 inch wheels.
RL Calipers are HUGE and ridiculously light. They weigh 8 lbs per corner fully loaded. The brackets are super light but the bolts are pretty beefy so let's call it 9.5 lbs mounted to be generous. The brake rotor hub rings are virtually weightless. The 12.8 inch rotor is chunky and comes in at 20.5 lbs. If you're feeling ambitious, you could put together this setup with some fancy two-piece rotors and save some weight. Thanks to 27Won for posting SI brake part weights on his BBK page. This would save 4-5 lbs off the complete front setup, a little less I'd imagine compared to the FK7. The rotating weight is considerably further from the hub but this is the case with all BBKs.
I was able to pick up the pair of calipers from the local junkyard for $40. The adapter kit is $170 shipped. If you're crafty and have the tools, you could probably make this yourself. I ordered new pads, caliper hardware, and rotors from RockAuto for $165 shipped. $375 all in which saves ~$200 compared to the SlickFab Genesis Kit. In that price, I'm not including brake fluid or the SpeedBleeders I installed. I will also admit that the RL calipers aren't performance oriented like the Brembos.
There are some considerations when it comes to frankensteining your own BBK together. An off the shelf kit, such as 27Won, is designed specifically for the car and made to work with the original BMC and ABS module. The factory caliper piston has a surface area of 2561 mm^2. The RL calipers have a combined piston surface area of 5809 mm^2. This is over 100% more piston surface area. Even the 6 piston Wilwood kit doesn't have that much surface area. There are a couple schools of thought on how this goes. One is that you're increasing front bias with all the extra beef up front. The other is that you're increasing rear bias because there will be so much extra pedal travel to fill up the big calipers with fluid, the rear calipers will be very pressurized. My decision was pretty much just to cross my fingers and hope the ABS module would figure it all out for me.
My only hard braking so far has been to bed in the brake pads. I didn't notice anything funny regarding brake bias or pedal travel. I still haven't noticed ANY difference in pedal feel for normal city driving, which I would consider a good thing. The brake line does contact the rotor at full lock. But if you're driving around at full steering lock all the time, there is likely an issue somewhere between the steering wheel and the driver's seat.
I considered painting them, but ended up sticking with the raw metal. I told myself I would clean up the calipers, but I got too excited after test fitting them with the wheels and ended up completing the install. I think it looks pretty pretty cool.
Happy Civic driving everyone!
The car is still on stands in these pics so ignore the monster truck height. And the pic of the stock brakes for reference was taken on the opposite side of the car.
Do you have the part number for the 350z rotors from Rock auto? Or a link for them?
bendrich
bendrich
Brighton, MA
2018 Subaru Impreza HB :'(
JBR1107EVC
That’s for the coated ones I got for going through salty winters. But it should lead you in the right direction. Just make sure it’s for the Z with the factory brembos
Jakupdoesnt
Jacob
JBR1107EVC
Thank you so much! I already have the calipers and the fast brakes adapter kit. I’m currently working on rebuilding them, I ordered stoptech brake pads. Gonna run goodridge brake lines and flush the system with Dot 4 brake fluid
CWIIIFK7
Charles
Atlanta, GA
2018 Civic Sport Hatchback 6MT
Great info in this thread. I actually picked up a set of 2008 RL calipers this morning. Cleaned them up, belt sanded the ACURA logos off, and prepped them for paint. My rotors and pads are on order along with the FB kit. Can't wait to put it all together. For those who have completed this project in this thread, how are things going with the upgrade? Any odd issues to speak of? Thanks in advance!
swanarg
TheSwanwar
Anwar
Los Angeles, CA
No issues what so ever. Great upgrade can’t complain. I did have an issue with loud ass EBC red stuff. Couldn’t get em to not scream on light breaking even after 1500 miles. Swapped em for r1 concepts oem+ which are quiet. Occasionally they briefly squeal on light braking but it’s infrequent and disappears with more pedal pressure. One touch of the pedal it’s there then gone. Maybe weeks at a time it won’t happen at all. Not an issue IMO
CWIIIFK7
Charles
Atlanta, GA
Thanks for that info! Glad to hear the upgrade has been good for you thus far. I'm stoked! I just loaded my calipers a few moments ago. Now just waiting for the FB kit to arrive along with my rotors from Rock Auto.
Honda Civic 10th gen OEM BBK: Acura RL 4 piston brake calipers DH_LPWMqFR5yTK7bHc3qNsozEo=w703-h937-no?authuser=0
Honda Civic 10th gen OEM BBK: Acura RL 4 piston brake calipers dD4TwnvTxq2gFnOpIR6dRFsou=w1250-h937-no?authuser=0
Honda Civic 10th gen OEM BBK: Acura RL 4 piston brake calipers 5D1BYve7_5FIceiYmj-_IN-6m=w1250-h937-no?authuser=0
CWIIIFK7
Charles
Atlanta, GA
Also can confirm the weight of these things loaded. Just under 9.5 lbs. I'm interested to see how much the drilled/slotted rotors weigh along with the FB kit components for a total weight minus the OEM rubber brake line. Unsure how much that piece weighs.
Honda Civic 10th gen OEM BBK: Acura RL 4 piston brake calipers T6Av_SA_AYBDXR5KYvpvUO5DYF=w703-h937-no?authuser=0
CWIIIFK7
Charles
Atlanta, GA
RL caliper upgrade complete. Found out my new wheels won't clear the calipers. The spokes would have made contact with the caliper. The wheels were Revolve APVD 1219 18x8.5 +30 but I'm assuming the spoke design is the culprit. I could have done a 3mm or 5mm spacer and they would have been fine but I decided to stick with my old wheels. Konig Ampliform 18x8.5 +35. They clear without issue. The Fast Brakes adapter kit went together fairly well. Had to use a bit of extra "effort" to mate the rotor centering rings to the hub but other than that no problem. I used Centric/Stoptech rotors and Powerstop Evolution Ceramic pads from Rock Auto. Car feels like it has stronger brakes immediately. You can really feel the difference in grab with the 4 piston Advics calipers. Pedal is firm and responsive. I have yet to fully seat the pads in but will follow up in a few days.
Unity Performance
Humza
Toronto, ON | Buffalo, NY
unity-performance.com
Current Fleet: 18 Si, 20 FK8, 23 FL5
Honda Civic 10th gen OEM BBK: Acura RL 4 piston brake calipers {filename}
Nice and light! I've measured the Gen Coupe calipers as well as factory Si calipers as well:
Honda Civic 10th gen OEM BBK: Acura RL 4 piston brake calipers u09L1SNvsf3tIDZR6k4uchtovwJpFV=s1521-no?authuser=0
Factory calipers -1lbs than displayed as stock pads were in at the time
Honda Civic 10th gen OEM BBK: Acura RL 4 piston brake calipers ZnNt8Ef4Ly0AzQJo0Y2hrK3T-P5FvH=s1521-no?authuser=0
swanarg
TheSwanwar
Anwar
Los Angeles, CA
jesus 14.5lbs nearly?! for one big ass piston haha, thats somewhere around 30% weight savings, cool!
Hondanickx
Nick
Belgium
The weight saving is none existing because you use a larger (heavier) brake rotor compared to stock. 350Z Brembo rotors are 20Lbs ,oem 282mm civic rotors are 13lbs and SI rotors are 17lbs.
So the 3.5lbs you lose with the calipers are gained back by the rotors.
You could also look into using Rear CRV 1.5T calipers and rotors (310mm)I think those would bolt onto the civic rear hub.
