CWIIIFK7
- Charles
- Nov 29, 2019
- 11
- 202
- 368
- Atlanta, GA
- 2018 Civic Sport Hatchback 6MT
For what it's worth my Stoptech drilled and slotted 12.76 350z front rotors were slightly under 20 lbs each. The OEM Si/Sport 18" wheel is 28.8 lbs. I'm running flow formed 18's at 19.5lbs each not including the tire. I can definitely feel a rolling mass difference over the completely stock setup. So I guess it boils down to your ENTIRE package.The weight saving is none existing because you use a larger (heavier) brake rotor compared to stock. 350Z Brembo rotors are 20Lbs ,oem 282mm civic rotors are 13lbs and SI rotors are 17lbs.
So the 3.5lbs you lose with the calipers are gained back by the rotors.
You could also look into using Rear CRV 1.5T calipers and rotors (310mm)I think those would bolt onto the civic rear hub.
