Keeping fog lights on without low beams?
Rommy
Los Angeles, CA
2016 Civic Sedan LX 6MT
So I was at a civic X meet the other day and I noticed someone had their fog lights on with only their DRLs on, no low beams. I forgot to ask the person how they did that. Is there a way to keep only the fog lights on without wiring a manual operation switch to the lights to operate them independently?
Shankmeyster
AZ
23 Si
Someone made a whole thread trying to figure out how to do this. He couldn't figure it out but was still working on trying to. Search for the thread as it should be in here.
Rommy
Los Angeles, CA
Spent an hour searching, can't find it for the life of me. Anyone know any additional info?
CivicXander
17 Civic hatchback Sport 6MT Rallye Red
Unplug the headlights or make a switch in the circuit
HBK
Ontario
17 Hatch Sport M6 WOP
Edit: Removed original idea as it wont work.
You have options but non that will rely on the fog switch in cabin. You can wire them to your DRL but will require a relay somewhere.
Two easier options:
1) You can modify the relay for the fogs in the fuse box to be turned on from the DRL signal using a fuse tap on the DRL fuse (assuming its switched).
2) Buy an H8 relay harness and power the fogs with an inline fuse from battery and signal the relay on the harness with the DRL connector behind the headlight.
Both solutions are faily ugly.
17 Civic lx
Cars stopped being able to do this right around the early 2000 era. E39 Bimmers can do it, E34 and so on... but on a German car its easier to figure out how to make them function that way since European market cars are able to do so.
SSGCoxie
ID, USA
2017 Civic HB Sport, 6MT, Sonic Gray
The problem is that the fog light relay under the hood is controlled by the BCM (body control module). This BCM is programmed to not allow fogs without low beams. A separate switch could be used to power the fogs independently, but you would lose the dash indicator when they are on as the BCM also controls this. It's possible, but not very pretty.
Dr_Drache
Michigan
1991 CRX - 2017 FK8 TypeR
so what you are saying is - we need to mod the BCM - easy peasy!
Romeoridgee
Honda Dealer Tech.
Rob
Maryland
19 SPT 17 EX-T 08 LX 21 CRV 12 Acc 14 328I CONV
jump the fog relay negative wire (on my 19 sport its on bcm connector b wire 15 purple) and the fog light activation wire (on my 19 sport its on bcm connector c wire 6 purple). fog switch wire will complete the ground for the fog relay and keep fogs on as long as switch is on, like the low beam lights, even if car is off. and will stay on when high beams are switched on.
TMUR
18 Civic Hatch, 06 s2000, 01 accord h-swapped
Will this allow for the dash indicator for fog lights to still function even when low beams are off?
Romeoridgee
Honda Dealer Tech.
Rob
Maryland
No I noticed because the computer doesn’t know the fog lights are grounded. The command is not aloud without low beams on. You’re basically bypassing the computer.
Ocelot
Ben
Manitoba
'16 EX-T sedan, '12 LX sedan
I haven't installed this yet, but I've made the harness up already. The NC contact on the relay allows OEM fog operation, energizing the relay with a switch allows override from OEM function. This way, you can have fogs automatically switch off when Highs are on, or leave fogs on all the time, incl when headlights are off and only DRL's are illuminated.
https://www.civicx.com/forum/threads/fog-light-override-capability.60376/
It's imperative that you actually switch the positive on the fog and not the ground. - otherwise when the relay is operated, you'll be placing a fault-to-ground and blowing the fuse (which I haven't drawn) or worse. On my 2016, the positive fog light wire is blue.
tonton81
Tony
Montreal
2016 Civic Touring 1.5L Turbo
fogs can be enabled on bcan bus via UDS messages, why mess with wiring? learn a hobby.
