Is this oil dilution?
Sam
Houston
2016 Civic EX-L CVT Ktuner Stage 1
Hi, all,
My car is 2016 Civic ex-l 1.5T. I got my oil changed 2 monsth ago and this morning I found the oil level exceeded the high limit?
I wiped out the oil from thr stick then dip it in, but this dipstick is really hard to see.
I live in Houston and drive 20min to school, like 20miles per day. It shouldn't have oil dilution. . . It's still under warranty, now shall I take it to dealership to check/fix?
Honda Civic 10th gen Is this oil dilution? 20181212_083644
Honda Civic 10th gen Is this oil dilution? 20181212_083434
Honda Civic 10th gen Is this oil dilution? 20181212_083625
NHCivicGuy
NH
2021 R
Did you check the level after the previous oil change? You're waiting until the car has sat for a while to check the level too, right?
Sam
Houston
No, I didn't check the oil level because dealership changed for me. I checked it in the morning before I turned on the engine. So it's cold overnight.
NHCivicGuy
NH
2021 R
It may be dilution, or they could've overfilled it when they changed it. Dealers usually put their entry level techs on oil changes..
Sam
Houston
Damn. I assume dealership would do everything right. So I didn't check at all.
SCOPESYS
Geoff
MD
Hi, all,
I wiped out the oil from the stick then dip it in, but this dipstick is really hard to see.
I agree... The Orange Plastic seems to make it far more difficult to judge the oil level, than the old style, all metal Dip Sticks - especially if the oil is reasonably new and still clear.
SCOPESYS
Geoff
MD
:rofl::rofl::rofl:
Thank you for that, I will have a smile on my face all day now, thinking about your post !!
latole
Vaudreuil,Quebec ,Canada
Welcome to the forum.
I do my oil change and wheel change myself.
I never go to a dealer I have my own trusty mechanic in my hometown
Gruber
Mark
TN
Any dealership (or any other shop) work has to be checked. The simpler the job, the more carefully it needs to be examined. If you had your transmission replaced at the dealer, or some other involved work like steering or suspension, you actually have a good chance it was done right. But oil or coolant changes or wheel rotations etc. are done by low paid dim boys and need to be verified in detail if you don’t want your wheel to fall off, drive without oil or with some strange brown fluid in your radiator (happened to me). I’m amazed how often they screw up, and how they can screw up again when they are asked to fix their previous screw up. After all, every employee is usually tested for drugs only once, when they are hired, and I hear in the news that we are currently having an extreme nationwide opiate abuse problem.
pjw7454
Pete
2017 civic couple ex-L
How can you check for bad wheel rotation or alignment? I have to get my first oil change from the dealer. I will more than likely dump the oil immediately afterwards and do it myself anyways bc the dealer wants records.
Gruber
Mark
TN
You can check if the the lug nuts are all in place and tight. If you have plastic wheel covers, you can check whether they put them back in correctly, or you might lose them on the way home (happened to my daughter). For alignment, check whether your steering wheel is oriented straight when you are going straight (happened to me - kind of annoying when the steering wheel is rotated several degrees).
NHCivicGuy
NH
2021 R
It's funny you mention lug nuts... my father had his rear wheels almost fall off on the highway doing 80 because they never torqued them down and the lugs came off!! That was a close one. Same thing happened to another friend I know, different dealer.
SCOPESYS
Geoff
MD
Mark -- you are so right !! (Unfortunately especially for those that put absolute faith in their Dealer) .
Talking of faith, I can see many similarities between "The Dealership" and "The Church" -- but talking about that in any detail would just get me into too much trouble :)
