Front grille coming apart.
givemeadollar
Matt
Multiverse
2018 Civic Si Coupe
I just got warranty work approved for this issue on my 2018 civic si coupe. Whole new front bumper assembly coming in around the 26th, hopefully this isn't just a temporary fix.
hikaru
Shawn
Marietta
Unless Honda changes the structure of the bumper, you will end up with the same shitty gap down the road.
givemeadollar
Matt
Multiverse
2018 Civic Si Coupe
Yeah, the service manager and I reached out to the body shop that will be doing the repair and we are going to try and figure something out. As of right now I saw on some post that someone had heated the clips up with a heat gun and bent them so they couldn't unclip themselves without actually breaking, so that may be the approach I attempt.
hikaru
Shawn
Marietta
Small cable tie will keep them in place, but the drawback is that the upper piece of the bumper may get curly surface over time. ABS plaStic, grill, tends to keep in shape, while the PP materials, bumper, shrinks over time from exposing to heat.
givemeadollar
Matt
Multiverse
2018 Civic Si Coupe
Interesting, I will definitely have to consider that.
pcsavvy
Vickie
Southern California
2020 Honda Civic Hatchback Sport (Sonic Gray Pearl)
I went to my local dealer about the front bumper replacement for a second time and I was told Honda would not approve the front bumper replacement a second time. Just hope it doesn't get worse than it is now.
givemeadollar
Matt
Multiverse
2018 Civic Si Coupe
If your local dealership is a monkey go to a different dealer.
pcsavvy
Vickie
Southern California
I also guess the dealer did not want to pay for the one day car rental for me.
nrtphotos
2018 Honda Civic DX
Honda ended up putting a new bumper and grill on my 2018 Sedan due to the grill popping out. I didn't have to fight them at all to make them do it either. The shop that did it was a quality bodyshop and the paint on the bumper is as good as OEM if not a better match than it was before. Unfortunately it appears to be separating again after only a few weeks. At this point I don't really care, it's not like my car will be worth less money down the road as they all seemingly do it. As for the 2019's, they had one on the lot that had a terrible gap and was a brand new car!
hikaru
Shawn
Marietta
I'd say they go with the same route for putting the bumper and grill together like the 16-18.
Honda Civic 10th gen Front grille coming apart. 3334237
NHCivicGuy
NH
2021 R
There's other cars out there that have a similar bumper/grill design like this and don't have the same issue. I think they just need to think of another way to fasten the grill to the bumper (different clip design or something). But yeah more than likely I bet the 2019s will face the same issue - we shall see.
hikaru
Shawn
Marietta
It's a bad design to begin with, so here's what you all can do instead of asking help from your local dealer for a new bumper and grill.
Remove the bumper and run 2 tiny cable ties through each retaining tab, or bend the retaining tabs in the grill by slightly heat it up to get a grab.
There's nothing much you can do if the retaining tabs in the bumper is broken though.
#2016civicgrillfix
Honda Civic 10th gen Front grille coming apart. IMG_2808
Honda Civic 10th gen Front grille coming apart. IMG_2809a
Honda Civic 10th gen Front grille coming apart. IMG_2811
HarlowQuinn
Harlow
United States
2017 Honda Civic
#2016civicgrillfix
How and where exactly did you run the cable ties? I'm having a hard time making it out from the picture and description.
Prelude2CivicX
Louie
Los Angeles, CA
2017 Honda Civic EX-T 6 Speed M/T, 2018 Honda Civic Si, 2018 Honda Accord Sport, 1997 Lexus SC300
Update: took my car to Honda and reported the issue to them they advised they will fix it but would require me to leave it for an entire day. I went in for maintenance service in an afternoon and didn’t want to leave my car there for almost 2 days. I will drop it off to them in a few weeks and update. The tech also advised me that they would have to remove the grill and adjust the the tabs somehow then re clip it back on for now.
HarlowQuinn
Harlow
United States
2017 Honda Civic
At least your dealer was willing to address it directly. I probably have to go to another dealership, the one that I go to won't even touch the grill. When the service manager asked the technician/mechanic what he found was wrong with the grill he said "I'm not taking that thing off". The manager then told me that I'll have to drop the car off at a body shop that they work with for them to evaluate the problem and then replace or fix it as needed.
