Have a turbo and a CVT? Considering a tune? Read this!
905Civic
Mississauga, ON
2017 Civic Hatchback Sport Sensing, 2020 Kia Telluride SX
The gtman! I really appreciate the help and I'll play around with it a bit tomorrow :) Cheers
Hollywoo0220
RJ
WA
@905Civic
If you really want to feel an immediate kick; as you are driving and above 35-40mph use your paddle shifter (while in D) and shift down to 3 and give it a push, you will feel as if you are in a M/T.
Food for thought :)
turbotiger123
Virginia
2018 Sport Hatchback
I dont know man I flash stage 2 but I honestly didn't notice much difference. ...
I was able to tell by the obvious increase in torque steer at WoT that my tune had taken. Didn't need a data log to tell me that.
But srsly do a data log.
905Civic
Mississauga, ON
Flashed this morning with the 21 PSI dual tune along with some quick adjustments - feels very nice :)
vctwhitepearl
Vic
Maryland
2020 Honda SI Coupe
For whatever reason, looks like you need to update Ktuner software. Quick adjust should look something like this, Tune 1, Tune 2, Tune 3 etc.....
Honda Civic 10th gen Have a turbo and a CVT? Considering a tune? Read this! upload_2019-3-29_22-15-25
Quick adjust can make your tune set and forget or as you move along here, there are ways to get unreal kick and lift. Study the default boost tables as they come in layout main and look at the graphs. Slight incremental changes can be made to bring out more power earlier in the lower to mid rpm's which then can surge to default final boost of 22 psi.
Ahhh gotchya! So just to make sure I understand, lets say I start fresh and create a new tune (the dual starter 21 PSI). When I go to quick adjustments it will show factory settings for everything. If I wish to, I can adjust those to increased I or II. Then save to my PC, then upload the tune to slot 1. Then, flash in the car.
Any suggestions for if I should adjust the quick adjustments from 'factory'?
Such as:
Along with early spool enabled?
BL55D
Lance
Australia
2018 Honda Civic RS
Such as:
how;s this setup working for you? no problems or anything?
JKessler
Jordan
Columbus, OH
2017 Civic EXT
+1 for KTuner and TSP Stage 1 Tune. This thing is a completely different car and so much fun. This is by far the best bang for the buck!
BL55D, I've noticed you asking the same questions all over the board about the "safety" of the quick adjustments. As I've said before they are all "safe". Just avoid disabling ramp as it's hard on the CVT.
If you want a good on the fly setup try this one. Enable early spool in the quick enables.
Tune 1 - 21 psi - aggressive
Tune 2 - 19 psi - moderately aggressive
Tune 3 - 16 psi - moderate
Honda Civic 10th gen Have a turbo and a CVT? Considering a tune? Read this! Capture (1).GIF
Myx
Delaware
@BL55D I wouldn't chance the quick settings if I were you. Better to have peace of mind in knowing you are ok then take a chance and not be. Don't do it! You'll regret it if something happens not to your liking. :)
So.....what have you chosen to do?
Myx, hope you're kidding cause this guy is a super newbie (trust me) and will worry he's ruining his engine because of quick adjustments. :doh:
Myx
Delaware
I'm serious! He should trust his gut feeling. I mean...I'm one with what you are saying but if he has doubts, he should trust his doubts and leave it alone. It'll make life easier for him. On the other hand, I'm having the time of my life. He should trust his instinct and leave it stock. Maybe get some seat covers or something. :)
BTW @BL55D I've been running my car with the aggressive settings for as long as it was available. I plan on taking the car to the track.....again.....for even further testing in just a few hours. I race my car a LOT. At a track of course. That's just me though.
If you were worried that eating apples were bad for you and you'd get sick and a bunch of people around you are eating those apples for as long as the apples were available and they didn't get sick.......and you still would be concerned, I'd be that guy telling you to trust your gut and let me have all your apples. **Food for Thought** {Pun Intended} :D
BL55D
Lance
Australia
2018 Honda Civic RS
Im actually running the same except for the boost ramp- only running improved ramp II and tbh im kinda comfortable with it. Its good to know theres that extra power i can lean on lol thankyou :)
  • Like
Reactions: Myx
BL55D
Lance
Australia
2018 Honda Civic RS
You’re right tho! I actually tried to go agreesive last night just to see how it would feel- i never reverted back hahah
Thanks man :)
  • Like
Reactions: Myx
Kane666
Jason
Pennsylvania
2018 Civic Sport Touring
i maxed everything...lol wish i knew how to adjust boost by gear properly.
An easy way is to just adjust it for "1st" and leave the other "gears" alone. Depending on your tires, try something like 16-17 psi to start. Also, it's a good idea to set up Advanced VSA. Try the medium setting. See if those changes minimize wheelspin.
