l15b7allturbo
- Jun 10, 2017
- 30
- 600
- 553
- San Diego, CA
- 2017 Honda Civic Si
i need glasses......It should ...it's yours
This pdf file is gold. Really appreciate you posting it. Hope to utilize it sometime in the month of September for an idea I previously had and trashed because of the intake piece itself.Just follow steps 13-27 and skip step 18. It's really not that hard at all lol no video needed because it wouldn't be that short. https://store.27won.com/support/instructions/L15_6_571_10_installation_instructions.pdf
Glad I could help as that guide helped meThis pdf file is gold. Really appreciate you posting it. Hope to utilize it sometime in the month of September for an idea I previously had and trashed because of the intake piece itself.
Any tips getting these bolts off? They look to be dam near inaccessible...This was a bitch to install. I would have gladly paid someone. couple tips, springs are useless, use the wire, wrap the bottom post with wire and have 2 extended on each side. run the wires underneath and pull blanket through. then wrap the wires to the top posts. It is a tight fit so if you have anything other than girly hands, you will not be able to snake it thru without pinching the wrap.
They are definitely accessible... Just need a good 1/4 ratchet and a couple of different size extension.. some bolts are further in than others. And make sure to either remove or move the intercooler coupling out of the way, that will help. I put on my turbo blanket a couple weeks ago myself.. the bolts are gonna be tight so what you can do is grab a small diameter pipe or an extension and insert in the handle of the ratchet so you can use it as leverage. You can do the same when installing them back on.Any tips getting these bolts off? They look to be dam near inaccessible...
Turbo response is held back by the factory tune, Ktuner is a great cure for that. Is the temp decrease worth it? That probably depends on how hard you are driving the car. I’d say for most people, it is just added engine bay bling.Have been waiting on a few tools to arrive and a free weekend to install this. For those that have it on, is it a noticeable difference in terms of temperatures and turbo response as claimed by PTP? To be honest, am just looking at lowering the IAT somewhat but wonder if this is worth it. Also thinking of wrapping the plastic intake tube above but prefer to keep the engine bay looking stock.
Any difference in IAT (pre and post intercooler) since installing this?This was a bitch to install. I would have gladly paid someone. couple tips, springs are useless, use the wire, wrap the bottom post with wire and have 2 extended on each side. run the wires underneath and pull blanket through. then wrap the wires to the top posts. It is a tight fit so if you have anything other than girly hands, you will not be able to snake it thru without pinching the wrap.
Actually yes, It hovers about 5 degrees above IAT1. It does not affect IAT1 because I am geussing that the MAP sensor also senses temps whcih is before the turbo. But if you want consistent IAT2 to be within 5 degrees while constant throttle, such as a track day, you will need an intercooler. You can definitely tell it is keeping the heat in the turbo.Any difference in IAT (pre and post intercooler) since installing this?
get a couple of extensions and you will be fine. Also, you do not need to pull it all the way out, just enough to swing out of the way to wrap the turbo.Any tips getting these bolts off? They look to be dam near inaccessible...
Awesome! Thank you!Actually yes, It hovers about 5 degrees above IAT1. It does not affect IAT1 because I am geussing that the MAP sensor also senses temps whcih is before the turbo. But if you want consistent IAT2 to be within 5 degrees while constant throttle, such as a track day, you will need an intercooler. You can definitely tell it is keeping the heat in the turbo.
I do not plan on running a tune because I want to retain the factory warranty and parts. I'm trying to decrease heatsoak, improve iat and efficiency of the car and stock parts by doing things like adding this turbo blanket, insulation wrapping (gold taping) the airbox, turbo inlet pipe, replacing the front grille with the aftermarket honeycomb one, etc.Turbo response is held back by the factory tune, Ktuner is a great cure for that. Is the temp decrease worth it? That probably depends on how hard you are driving the car. I’d say for most people, it is just added engine bay bling.
Sure it might but anyways baby turbo so you won't feel anything lol maybe get an overboost code because of it hahahahI do not plan on running a tune because I want to retain the factory warranty and parts. I'm trying to decrease heatsoak, improve iat and efficiency of the car and stock parts by doing things like adding this turbo blanket, insulation wrapping (gold taping) the airbox, turbo inlet pipe, replacing the front grille with the aftermarket honeycomb one, etc.
So you're saying this won't cause the turbo to spool slightly quicker and run more efficeintly, even without a tune?
I also found this article which was interesting (the colder the intake air, the more efficient the turbo and lower the intercooled temps):
https://motoiq.com/Compressor-Efficiency-and-More/
