1.5T PRL Motorsports 1.5T Civic Bolt-On Big Turbo Kit Upgrade Results
Hatchbackboi1
Ca
'17 Civic Hatchback Sport
@PRL Motorsports
So how will this work on the CVT? Is it worth to spend around 2-2.5K for this turbo kit knowing that the car has a CVT? Can the torque be limited to around 250 while having around 320hp?
also with a CVT hoping to hear good news of possbiilty safe tq but higher hp
charleswrivers
Charles
Kingsland, GA
You could limit boost down low and keep torque from exceeding 250 ft-lbs and still end up with around 300 hp at the top. While it might be a little dead at the bottom and linear in the top 1/2 of the RPM range... with the CVT, you'd still just lock in at peak power and let your CVT unwind. 250 ft-lbs @ 6500 RPM is right at 310 hp.
Edit @360glitch won this race with ~320 hp to my 310... and a few seconds.
Matthyahuw
Matthew
Valley of the Sun AZ
2018 Agean Blue Civic Si Sedan 2016 Omaha Orange Jeep Renegade Trailhawk
you can make a very large-mouth breather with a larger, later-spooling turbo and don't go over 6k.
you'll lose a bunch of low-end, so it's a trade-off
LilToTo17
Kevin
Santa Rosa, CA
wheelwell.com
Well should have a professional tuner do it for you then.
charleswrivers
Charles
Kingsland, GA
Yep. Run it on a dyno and you'd actually be able to know the exact output through the range. Ask them to run it with low-ish boost for a baseline then use the follow on pulls to dial in how you want to put down the power... stating you want to not exceed X torque value. They oughta be able to adjust the boost targets to meet your needs, and validate it on the Dyno.
Afdad120108
Shreveport, La
2017 Honda Civic Si
I see the kit comes with a re-circ BPV. Safe to assume that we will not be able to have it vent to atmosphere? I thought I read that somewhere originally the kit was going to allow us to have a BOV
Two Step Performance
twostepperformance.com
Air is being metered the same way as stock, so you would have the same issues here if using a standard BOV.
kshawn
Matthew
Maine
2017 Civic SI
I’m planning to either go full bolt-on PRL with CVT cooler as well on flex fuel, or Big turbo kit with CVT cooler on 91. Which option do you guys recommend to me?
i remember the same. they must of went away from the BOV
Micah
Toms River, NJ
Want a BOV? Buy MOTEC, pay a tuner to convert to MAP based tuning. Anything can be done ..... and done well and correctly if you are willing to pay for it.
Afdad120108
Shreveport, La
2017 Honda Civic Si
Very true. Only reason I asked is originally I thought this would be an option with the kit. Either way still an awesome kit that I will definitely be getting
zroger73
United States
V8-levels of horsepower and torque from a tiny 1.5L 4-cylinder engine. Impressive. :)
CrippleRipple
Kansas
2018 Honda Civic Si (LSM)*SOLD* & 2018 Honda Accord Sport 2.0T (SNP)
Any ETA on price & options?
LilToTo17
Kevin
Santa Rosa, CA
wheelwell.com
Going to need internals eventually lol who knows how long these motors will last with that much whp and wtq
