SukiHonda
- Chris
- Oct 15, 2020
- 4
- 36
- 58
- New York City
- Honda Civic 1.5T EX Hatch
- Build Thread
- Link
Hey all I just finished installing my PRL intercooler. For clarification I did not upgrade the charge pipes so this was a FMIC upgrade only. I think a mod list would be needed before I jump into what I’m experiencing.
2020 Civic EX hatch CVT (FK7)
- PRL Short Ram Intake w/ Race MAF
- KTuner V2 currently running Phearable 1.5R tune
Pre PRL Intercooler upgrade experience
Car felt nimble and zippy. My STFT1 was hitting around positive 15% when I was pressing on the peddle. I didn’t worry too much about this since I had recently upgraded to PRL SRI w/ Race MAF (during stock MAF STFT1 would never go or get close to positive/negative 10%) which I knew was letting in more air. Plus when off the peddle and cruising I was 0% on my LTFT1 and STR1 or damn there with in 3% positive/negative. LTFT1 was always with in 3%-0 positive/negative depending on my driving that day. The PRL SRI sounded like as it is normally advertised. It just started getting warm here in NYC last week so I decided to by the Intercooler especially since I installed a SRI. My temps pre install was about 143 F for IAT1 and 114 F for IAT2 give or take. ECT can be around 178-205 depending on the type of traffic I’m dealing with. Before it started warming up outside I was seeing a constant 70-90 F for IAT1 w/ IAT2 being as low as 60-40 F, again give or take.
Post Intercooler upgrade experience
I tried following YouTube and the manual as close as possible but it seems the manual and videos online are more tailored Towards upgrading the Intercooler with the charge pipes. When upgrading the FMIC only the cold and hot charge pipe adapters are different. I followed the manual step by step but when it came to the adapters I had to use the small diagram PRL provided. Since I am a visual learner this got me worried the install is incorrect. I’m almost 99% sure I did everything correctly but that 1% is haunting me since I can not confirm anywhere online visually just with the diagram. Now when I first received the Intercooler there were about 1-3 fins bent nothing drastic but it was noticeable. The fins that were bent was locate on the back of the Intercooler and I’ve read it will not effect the Intercooler performance if a few are bent and the angle of the bent is not too much which it isn’t. I triple checked my work before putting the front bumper back on and everything was tight and solid. All bolts were tight and all connecting parts were sealed tight. After putting on the bumper I noticed two hex screws remaining.. I’m thinking I might have reused the stock 10mm bolt to seal the driver side adapter to the stick charge pipe but again everything was sealed and can’t really see this as a reason for the following issues especially since The bolts were used in the same screw hole but hey I could be wrong or maybe PRL sends two extra hex screws??
When I hopped in the car for a test drive I noticed a-lot. The biggest one being my IAT temps. They were pretty similar to what it was pre Intercooler upgrade. During the test drive outside temps was a cool 67 F my IAT1 would range from 90-120 and my IAT2 would be 80-110. Which I thought was strange since reviews people were claiming heat soak isn’t even a thing anymore, given I have a SRI w/ Race MAF I wasn’t expecting extreme results but generously something a little better than stock ranges.
I also noticed strange behavior in my fuel trims. My STFT1 are currently hitting positive 20-30% when on the peddle. When letting off the peddle sometimes it would go to 0%, sometimes it stays at 20-30% positive and negative, sometimes it would stay at 20-30% for a sec or two then drop to 0%. My LTFT1 was acting strange too. To my
Understanding LTFT1 is more of “habit” and is based on car usage. During test drive I been going pretty heavy on the gas probably 50% I also did a WOT pull at one point. My LTFT1 slowly raised to 10% over a few mins of driving and then slowly go back to 3-0 % with in another few minutes. I don’t think that would be too concern since I was kinda beating the peddle. I don’t usually go pass 30% consecutively on the peddle so something like this with my LTFT1 is rare to my eyes and I’m hoping it’s normal. My STFT1 is really concerning me the most.
Monitoring my MAP sensor I start at a negative 9-10% when off the peddle. When building boost and on the peddle I get to 10% and let off. The boost build up is consistent, I can’t really hear any air letting out during the build up. It feels like it’s supposed to and the numbers work like they are supposed so I’m not really sold on a boost/vacuum leak. I didn’t really take it pass 10% just in case there is a leak I’m not damaging my turbo too much.
Now with PRL SRI the sound did kinda change. Instead of the immediate medal, sudden, blow off sound you can hear That same sound was but more of a hiss as the sounds fades out. I admit it sounds way nicer but I’m afraid that hiss fade out sound is because I do actually have a leak somewhere… I can always upload before and after sound clicks.
Finally I use the old turn off eco mode and drop to S gear for a nice seat sink feeling or a way to merge safely or fast. Now that I’ve installed the Intercooler I don’t get that feeling anymore. Matter of fact all gears feel like it’s lacking in power from eco mode to L gear. Again I don’t think this is due to a boost leak since I build up consistently but maybe due to the heat soak since the Intercooler isn’t doing anything? This is my first time experiencing warm weather with the SRI so I never really felt my car heat soaked and loss of power because of it.
I currently have no engine codes as per KTuner and dash lights. I will try to do some data logging tomorrow in the night and will post here.
My questions are:
1. Why are my fuel trims especially STFT1 so weird?
2. Shouldn’t I notice a considerable difference between IAT1 and IAT2?
3. Why does my car have a feeling for lack of power?
4. Possible leak somewhere?
5. Should I install the proper bolt?
I’m really sorry for the lengthy read but just wanted to be as detailed as possible and sorry for the lack of close up pics.. I totally forgot to take pics I was just too excited. I really would appreciate any feedback.
My questions are:
