That may work too, it's just the online part catalogs that I search still doesn't have the 2019 Hatchback yet, and not sure if the Sedan and Coupe ones would fit... Have we confirmed the 2019 Hatchback has that?The light from a 2019 should be an easy addition. You would only need the illumination wire and a ground and some solder.
I am really looking for that catalog too. Want to add the fan +/- controls and the larger cup holders. I suppose we will just have to be patient for now :/That may work too, it's just the online part catalogs that I search still doesn't have the 2019 Hatchback yet, and not sure if the Sedan and Coupe ones would fit... Have we confirmed the 2019 Hatchback has that?
You just tap into the illumination circuit, the same power source that lights up the climate control. Finding that wire, well that would be tough but not impossible. FOr me it was easy cause my car came with the interior illumination kit installed.Hmm, that's an interesting insight, so the power source better be something turn off when the car is off, like the accessory, and perhaps something to sit between the switch and the box... Getting interesting
Haha, shouldn't be hard for me, I have just installed the illumination kit and the door liner illumination kit (and the center console kit) lately, the door one light up when it's accessory mode or the car is on, and the other 2 is on with the headlights, so I guess I'll just tap the door one.You just tap into the illumination circuit, the same power source that lights up the climate control. Finding that wire, well that would be tough but not impossible. FOr me it was easy cause my car came with the interior illumination kit installed.
Great... it's the same part for 07-09 CR-V as well.I have a UK spec 1.5T Sport and just fitted the red LED sill kit and footwell light kit. In the process I damaged the rear part of the glovebox that the damper is attached to. I have my own automotive business and so this job was an easy fit but the trim is very fragile. Here is the Honda WebEPC schematic...
I have installed the console and footwell illumination kits, and my door illumination kit just come in so I'll be doing the same as well while I'm doing the install of the door one.Haha, should be hard for me, I have just installed the illumination kit and the door liner illumination kit (and the center console kit) lately, the door one light up when it's accessory mode or the car is on, and the other 2 is on with the headlights, so I guess I'll just tap the door one.
Looks like 2019 will have money to be spent
I just found these on google doing the glovebox light for the 8th gen civic. I'm sure that the glovebox light is the same, but with different mounting angles which leads to different part number. The connectors should be the same.Yea I understand it may not worth to make something not mean to be on the car works, but I think this is something the car is designed to have, at least for a different market, and I'd love to reach its potential While I'm searching on that light assembly, I see other Honda forums (like the Fit, CRV, and Accord) has similar projects too, after all it's about the fun of DIY.
The light assembly, seems like it's also used in the 07-09 CRV here in the states, so dealers should have the part. Then I've also look into the Connector and wires, and these 2 parts may work (would be great to have stephenmeadows confirm on this)
04321-SH2-307 and 04320-SP0-A00
Bad thing is they come in bundles, so ordering one for each part number will give us more then enough parts (Or spare parts for other projects )
After getting all these, I can see the next step is to tap the wire to an accessory power source, find a good ground, get a nice T10 LED bulb, and call that good.
That's exactly the same picture where I knew about 04321 & 04320, just not sure how to use 04323I just found these on google doing the glovebox light for the 8th gen civic. I'm sure that the glovebox light is the same, but with different mounting angles which leads to different part number. The connectors should be the same.
I can't find picture of 34760-TY2-A01, but I think it will look something like these. These are identical to the footwell light, which requires self taping screw to secure, but these are easier to install and remove but harder to fabricate the round shape with tabs.Could that be the same idea of installing the ambient kit? Drill holes on the panel behind the glove box and have that light on all the time ?
Doesn't sound like a way honda would do though...
I'm guessing (however it would work) it's for the Sedan and/or coupe models, since the ambient light assembly has a different shape as the 34254 parts, but who knows
Yea, I think I'll go with this route, I've ordered 34254-SWA-003+04321...+04320 for this project. I can already see myself putting a LED T10 into 34254I can't find picture of 34760-TY2-A01, but I think it will look something like these. These are identical to the footwell light, which requires self taping screw to secure, but these are easier to install and remove but harder to fabricate the round shape with tabs.
I'll go for 34254-SWA-003 with switch because it's maintenance friendly, you just need to replace the bulb.
You have to replace 34760-TY2-A01 if the led in the assembly is done.
