AdamD19DFK8
- Adam
- Jul 11, 2019
- 5
- 679
- 376
- Maryland
- 2020 FK8 Type R, 2007 Civic Si Sedan
I think I'm finally getting somewhere! Last night was pretty cool out so I went for some pulls. I'll upload the log when I get home from work. On this Mexican highway everyone is at least going 70 so no 3rd gear pulls. I did a lot of pulls from 4th gear through 5th and I noticed my 85-130mph times were quicker than what I would get with the base map. 1-2 seconds quicker.
Also something bizarre I saw in my logs is when I was pushing to the top of 4th gear and into 5th up to 130 my fuel pump duty was only 74-78% at WOT. Dafuq? If that's the case it looks like there is room for more.
For the calibration I increased the throttle torque targets by 15% so Max of 552nm request. I advanced ignition timing by 3 degrees. I did not touch my air charge limit values however I did increase the pressure ratio slightly. If I recall correctly during WOT while pushing it my boost say around 24-25 psi.
If I'm not even hitting 80% fuel duty up top what should I look at increasing, bumping up the aircharge would just increase pump duty with no gains I'd imagine. Also not sure pushing the ignition timing any higher would be beneficial, I like what I'm getting with plus 3.
Once I'm able to put up the log this afternoon or should help
