- JOHN BOY
- Aug 4, 2020
- 5
- 151
- 51
- SW
- CTR 2020
- Banned
- #811
Is it ok to run EGT disabled if you are running E30 Tune on Hondata? Also the 2020 CTR will this help EGT in any way since the engine bay has more cold air coming in?There are two cat temperatures. The temperature where fuel is added to keep the EGT down, and then the maximum temperature. We reduce the lower temperature so that ECU does not run stoichiometric too far into boost, but that is a balancing act since it is around peak torque and it is easy to run out of fuel pump. Anyhow, that's why you see a temperature which is lower than the EGT temperature.
I am a newb
