Do you think that a type r exhaust would fit ?I would figure it would fit for the most part. A good shop could make it work if you bought a Coupe exhaust. Not sure if there's any real differences between the Touring and Si Coupes in terms of body (ex. I have an EX-L hatchback and because of my spare tire kit, I can't use the same exhausts as Sport models because the tire holder sits too low).
I highly doubt it, not unless your shop does a lot of modification.Do you think that a type r exhaust would fit ?
I would imagine the coupe Si would be a much closer fit than the Type R exhaust would, but there will definitely be some custom fab required either way.So the SI exhaust is possible?
Sorry for asking so many questions, what is a fab?I would imagine the coupe Si would be a much closer fit than the Type R exhaust would, but there will definitely be some custom fab required either way.
Fab = fabrication. Means it will not be completely bolt on / plug and play, there will need to be some modification/fabrication done to make it fit properly. What that entails, I honestly wouldn't know.Sorry for asking so many questions, what is a fab?
I have a 2016 coupe touring, will an SI exhaust or a type r fit in it?Many people have put the stock type r exhaust on their non type r civic. Most don’t keep the stock one after removing it for aftermarket. It should be relatively cheap for the actual exhaust but welding work would be a couple hundred.
But it’s not bolt on and will need welding. There are very few coupe exhausts options available.
Anything will fit. Its just a matter of how much money you want to spend at an exhaust shop to have it made it. The only thing that will fit without custom work is an exhaust made for your make and model of car.I have a 2016 coupe touring, will an SI exhaust or a type r fit in it?
So technically I would only have to buy the exhaust tip of an SI or Type R and not the full set?Anything will fit. Its just a matter of how much money you want to spend at an exhaust shop to have it made it. The only thing that will fit without custom work is an exhaust made for your make and model of car.
Correct. You need to get under there and look. I have a 2021 EX so i dont know the layout of the older ones. But there is a big difference in the EX/LX and the sport models. I cant use a center exit exhaust as the tire carrier sits lower on my car and is in the way.Also, the bottom diffuser would have to be replaced right? So that the exhaust tip could fit
