CVT Fluid Change 2016 Civic EX
awgfl88
Andrew
Tampa FL
Honda Civic 2016 EX 2.0
Good Afternoon Everyone,
New to forums, hello!
Been reading through all the threads on here but cannot find anyone who seems to have successfully changed their own CVT Trans Fluid in a 2016 Civic EX 2.0.
Wondering has anyone managed to do this yet?
My dealership is trying to quote me $200 to have it drained and filled which is crazy since I can buy the HF2 CVT Fluid for $8.11 a qt.
I'm looking and can see the transmission below the engine air filter, it's obscured but think I can make out the drain plug.
Wondering if anyone has done this themselves yet and can point me in the right direction.
A co-woker of mine has a 2016 Accord which has a dipstick and an easily accessible fill plug, I cannot see that on my Civic.
My best guess is that I'd have to remove the Engine Air Filter housing to access somewhere to fill the transmission fluid up after draining, I was wondering if anyone knew this to be the case after doing it themselves?
Thank you very much for any input.
GeoUSA
Virginia USA
2017 Civic EX Hatchback
Any chance you ever hear a grinding noise when you start your Civic? If so you may find this thread interesting:
http://www.civicx.com/threads/warm-start-grinding-noise-news-fix.9952/#post-167233
There is a TSB to correct it and it includes a CVT fluid change. I have the grinding noise. TSB says reliability is not impacted so I am not in a rush to have this corrected yet. I do recall someone talking about changing their own CVT fluid -- and I believe it may be in that thread. If not, with search I see a few other CVT fluid change threads.
dc2turbo
usa
civic,teg
i think you only need 4 qts for a fluid change.
you just drain it and fill it back up from the fill plug
awgfl88
Andrew
Tampa FL
My problem is, where is the fill plug?
I can see the drain plug but the rest of the tranny is obscured by the air filter housing.
awgfl88
Andrew
Tampa FL
Can't say I do hear a grinding noise, thanks for the info though.
awgfl88
Andrew
Tampa FL
Excuse me guys, I'm being stupid, got the car up on a lift, now I can see the drain is on the bottom of the tranny and the it's a side fill. Need to go down to the auto store and get a pump to change it. Problem sorted I think!
Still, if anyone has experience doing it themselves I'd love to hear more.
indexcow
Redding, CA
2016 Honda Civic EX (Crystal Black)
@awgfl88 no one has posted pictures of a CVT fluid change yet. Would you mind taking some pictures and making a little how-to in the how-to forum?
dc2turbo
usa
civic,teg
its on top of the cvt. theres only one plug there that looks like you can lift up. its white with the letters HCF-2
awgfl88
Andrew
Tampa FL
Really? So I will have to take the AF housing out to access it then? I can't see the top of the tranny.
awgfl88
Andrew
Tampa FL
Yes Sir, intending to do it Monday when I can get the car on a lift again. Will try and document with pictures and maybe do a Youtube video too, I'm sure other people are looking for the answers also.
dc2turbo
usa
civic,teg
I'm not sure if you have to take the intake box off but its easy. only a few bolts
Honda Civic 10th gen CVT Fluid Change 2016 Civic EX upload_2017-10-12_13-33-36
awgfl88
Andrew
Tampa FL
That's not a 2016 Civic EX, at least nothing like what mine looks like...
fjrman
Tennessee
2016 Civic 4 door LX with CVT
View this thread. Follow "brox" and his commentary beginning at comment #83. He has a '16 EX 2.0 CVT.
http://www.civicx.com/threads/cvt-fluid-change.10395/page-6
The top rubber filler plug is very hard to access on the 2.0 CVT.
brox used the oil level check port on the front of the CVT for filling with new fluid. He never removed the rubber plug up top.
Same procedure as one uses for an oil change in a Honda manual transmission.
