Clutchmasters FX-350 with single mass flywheel
kshawn
Matthew
Maine
2017 Civic SI
Just received my fx350 with single mass flywheel! I'll hopefully have it installed in the next couple weeks :)
Once it's in, I'll be doing before and after break in review.
Honda Civic 10th gen Clutchmasters FX-350 with single mass flywheel 20180613_151307
Honda Civic 10th gen Clutchmasters FX-350 with single mass flywheel 20180613_151242
LilToTo17
Kevin
Santa Rosa, CA
wheelwell.com
Let me know about the codes it’ll throw if misfire detection isn’t disabled
kshawn
kshawn
Matthew
Maine
2017 Civic SI
kshawn
kshawn
Matthew
Maine
2017 Civic SI
Shop is installing right now. I'll probably have my car back tomarow. But hopefully today!
davemarco
Was thinking about this yesterday. If you wouldn't mind, I would love to get your feedback on the clutch/flywheel combo with the various rev hang and throttle padding combos. Like most of the KTuner owners here, I've been using the full rev hang delete with Standard (none) throttle padding. Lately, it's been getting a bit jarring to use though.
I feel that with the stock flywheel, the revs fall too slowly to use anything but the full delete w/ standard padding. However, if this flywheel causes them to plummet much faster when clutching in, I may switch to a softer padding setting. It will definitely be interesting to see.
kshawn
kshawn
Matthew
Maine
2017 Civic SI
I'll be doing a full follow up after a little driving. Then another after break in! And I have rev hang disabled as well, tho I have throttle padding on soft.
I'm expecting the rev's to drop a little quicker with this. But I'll make a note to mention the before and after affect. I'll probably have a video in the review.
davemarco
Thanks, much appreciated. Just out of curiosity, how is the transition to vacuum on the soft padding setting? On Standard padding, I feel like it is impossible to smoothly throttle off - it feels like you can smoothly transition down to like 10% throttle, and then you immediately "fall" the rest of the way to zero.
kshawn
kshawn
Matthew
Maine
2017 Civic SI
It's much better then the other 2 options. Which is why I keep it on soft. But I'll use the more aggressive setting when I'm going to meets
