Austin@Wunderladen Racing
- Austin
- Dec 6, 2021
- 46
- 1,105
- 2,319
- Chicago IL
- Website
- www.wunderladenracing.com
- 2018 FK7
I wasn't quite clear enough with my explanation, apologies. By initial bite, I meant cold bite. The P3 compound being a hybrid street/track compound won't need much heat to get into its peak friction zone, compared to the R5 which needs some heat in it to work most effectively. When you couple a pad with a lower temp range on a significantly larger rotor it shifts bias to the rear a lot. Balancing bias with compounds can be tricky because the Mu (friction) of the pad will change as temperature rises so bias favor can bounce from one axle to the other as temps change.
When a car has rear favored bias the rear end will feel unsteady during braking. When a car has front favored bias the car will feel almost like it's understeering during braking, because it's sliding in a straight line. Front bias is pretty much always preferred for this reason. FWIW, I am not aware of any sport compact that uses rear rotors as large as 350mm, most are in the 280-300mm range. The only cars with very large rear brakes that come to mind are some Porsches and that's because of their weight distribution (heavily skewed to the rear).
I certainly hope to make it out there one day! I'll be out at PPIR in CO in two weeks but that's about as far as I go right now, the 20+ hour trip each way is rough haha.
