- Mitch
- Oct 27, 2015
- 334
- 17,001
- 24,788
- USA
- Website
- www.civicx.com
- 2017 Cosmic Blue EX-L Sedan
- Vehicle Showcase
- 2
I see people at the forum asking all the time if the aluminum pedals from the Sport and Si fit the "regular" models. The answer is a resounding YES.
Here are the instructions (including the part numbers for both CVT and manual):
http://www.collegehillshonda.com/instructions/civic/2017/5dr/sportpedals.pdf
But, there are a few things to keep in mind...
First of all you need the right tools. You'll need a drill, a pop rivet gun and some masking tape. If you don't feel comfortable drilling into your gas pedal or don't own a pop rivet gun, have a dealer install them. Also, the hole size you need to drill is an odd size (3.5mm) so like I did you'll probably need to buy a drill bit online. Some people have removed the gas pedal assembly to do the work, I just installed it in the car.
Mini DIY (CVT models):
The brake pedal is easy. Just remove the stock rubber pad and discard. Install the new rubber pad that comes with the pedals. Then put the aluminum pedal over the rubber aligning the holes (no drilling is required for the brake... the holes are already there). Then you just pop the rivets into the four holes. Warning: You will have to really muscle up on the rivet gun on the brake pedal.
For the gas pedal, you need to drill four holes in the stock pedal. First, tape the new aluminum pedal aligning it over the stock pedal. Drill the new holes with the 3.5mm bit. Then it's time to pop in the four rivets. These rivets go in very easily.
Admire your new pedals. Done.
