WOT pulls, how often?
Mikeybc
Northern Ontario
2017 Civic Coupe EX-T, 2015 Nissan Murano
I usually do a couple WOT pulls each way to and from work, I rarely ever go over 5,000 rpm. Doesn't seem to pull any different at 6 k as it does 4K
The Vyzitor
The Vyzitor
This thread is about whether the CVT can handle being pounded WOT every day, not the Si. The Si was built to be taken to redline. Taking the CVT to red line by putting the pedal to the floor makes no sense. The power curve drops off fast in the higher revs.
so what about going WOT but short “shifting” with the paddles to avoid the higher RPMs? Is that beneficial or not really
The Vyzitor
The Vyzitor
The 1.5 turbo has a beefed up CVT from the Accord. JR from KTuner tested his EX-T for thousands of miles before his tunes even went beta. Many of those miles had WOT pulls. He was totally impressed with the robust-ness of the CVT. Yeah that's right, his tunes were originally designed for a CVT 10th gen, not a manual. Hondata's tunes were originally CVT only as well.
http://ktuner.com/ktuner-civic-x-testing/
Derek who created the TSP tune, designed the tune with an incredible top end. Reason being? It's not the high rpms that's the issue for the CVT, it's too much low end torque that's the enemy.
No one is saying to constantly go WOT, but these cars handle it fine. Matter of fact an occasional spirited drive is probably better than never going beyond 1/2 throttle. The trick with the CVT is not to launch it but do WOT at speed.
And for the record this thread is about WOT pulls so even though the OP has a CVT, I don't see why Si guys can't respond to a member saying my car will blow up.
That is fantastic information to know, thank you! Do you know what Honda did to the trans to beef it up? I know the WRX is available with a CVT and they’re not exploding on every street corner, so a CVT must have some kind of performance potential if built correctly
The Vyzitor
The Vyzitor
I kind of don’t get where this came off the rails? WOT pulls doesn’t mean you’re exceeding or bouncing your engine off the rev limiter. Also, I’d assume the CVT would be programmed to make the engine RPMs to rise to peak power and stay there, then dynamically change gearing to allow speed to increase. This ought to be around 5500-6000 RPM. A CVT equipped car *shouldn’t* hit the engine rev limiter unless the software is altered. Without some different boost targets (the cars do have a boost taper on at least the reflashes) or, even more, a different turbo, CVTs should stick it at peak power. I figure they’d also force up/downshifts if you were trying to play manual mode.
OP, if you can’t aggressively drive a car without it falling apart, then its so fragile it’s probably not worth having. There are no warnings I see in the manual about redlining our cars other than staying you may feel a jolt (fuel cut) and for the manual guys not to downshift such that you’d exceed redline (money shift). My Z31s talked about not racing an engine at idle for greater than a minute and the Z32 discussed use of different plugs if you were maintaining high engine speeds/loads for an extended period of time. There’s nothing in ours to limit operation at/near redline. The car makes peak power over the 4500 RPMs you’ve pushed it to. It’s there to use if you want it. CVTs are an acquired taste... and while it may feel unnatural at first to have engine RPMs hang while the speedometer keeps counting it, you may be surprised, even on a stock tune, how quick the little car can accelerate by it providing constant peak power.
I drove a few slower CVT equipped cars that were lackluster. I recall test driving a VQ35 equipped Altima with a CVT and not being wild about its torque limiting off the line, but as a pinned the throttle to go on a long on ramp and looked down wondering what was wrong as the engine went to just under redline and just droned on and on... I looked over and saw the speedometer was nearing triple digits. CVTs definitely make the most of what engine power there is in a straight line.
I’ve never tried a CVT equipped L15B7 powered Civic, but I’m sure it’s as quick as a straight line as my Si until 80 or so as I get to 4th and keep on pushing it. The Sis are fun to row and would handle better, though non-Sis handle fine in their own right. This has been proven. Instrumented tests for a down-on-power EX-L w/a CVT and a Si when the Si has all-seasons are within .1 sec for both their 0-60 and 1/4 mile. If the Si driver makes the slightest mistake, he’s sunk.
...and I agree, the forums aren’t quite what they were when I first joined. Maybe it’s because we’ve figured out how much you can wring out of the cars on their stock turbos and the TSP reflashes have been out for over a year, at least the Si pump gas one. The cars are still a bit new to get overly experimental for the average joe but also new enough a lot of fixes for things haven’t been shared because they’re being handled by the 3 yr/36000 mile warranty for most. I hate that Vits blogs which were a wealth of info, are gone. I really enjoyed reading them and making/reading random posts about digging into Ktuners functionality when I was modifying my basemaps.
Yeah the CVT is the main detractor for going WOT for me. Still getting used to it in a more performance oriented car. I never minded the CVT in my LX but I also never even thought about driving the LX hard at all. Most of my previous cars have been manual, and my wife’s GTI is a DSG automatic which is fantastic (why couldn’t Honda have gone with a dual clutch auto instead of the CVT!!!)
The CVT gets a bum rap because it's different. It feels different because there are no real gears. It definitely takes some getting used to. It's basically one "gear" that constantly changes rpm's depending on load and throttle and other factors. They are mpg efficient and generally put the engine where it needs to be in the powerband. They are potentially so good that they were banned by Formula 1 racing.
IMO, the CVT/1.5 turbo combo in our car is actually quite good, except in one scenario. For example, you need to make a left hand turn at an intersection. You're stopped. Opposing traffic is heavy. You see your window of opportunity and you gun it. Unfortunately, you get some turbo lag and "CVT lag" that can make things dicey. It takes a bit for the CVT logic to catch up to the heavy throttle input.
It was this exact issue that got me into tuning. With KTuner, you can more or less tune out turbo lag and improve throttle response. Now in these same traffic situations the "hesitation" is quite minimal.
Not everyone tunes for ultimate power. I didn't. But knowing you have the extra power sure doesn't hurt.
Here's some info from Honda regarding the two CVT's for the 10th gen:
Honda Civic 10th gen WOT pulls, how often? IMG_20191024_034846
Honda Civic 10th gen WOT pulls, how often? rps20191024_035640
Hope this helps.
SDAlexander8
Steve
Indianapolis, IN
That might work. There’s nothing wrong with going into higher RPMs with the CVT if your car is still on stock tune, I just don't think it’s the most efficient way to drive it. I have not driven a 1.5T CVT civic, just the N/A 2.0. I say play around with it on an open road. Floor it and see where in the RPMs you start to feel less pull, figure out where it starts to drop off and use the paddle to shift at that point.
trapbryan
Bryan
Miami, FL
2019 Civic SI Coupe
I know its about CVTs but but I drive my si like I stole it every day lol. 95% of the time on tsp stage 1 map 3 sport mode .
SiGeddy
Geddy
Bakersfield
2017 civic si
I feel like a rarely floor it in my Si since I've been tuned. Whenever I have its usually in 2nd gear and the stock all seasons just spin, so it's not enjoyable.
Maybe after I upgrade my tires that will change tho :drive:
aighead
Dayton, OH
snortcoffee.com
2017 Civic Si, 1988 Ford f250, 2004 Honda vtx1300
After paying attention I think I spoke too soon about 1st and 3rd gear. 2nd is also fun, but I like the tire spin a little, it makes me laugh.
Zodd
david
Slovenia
civic sport 1.5t 2018
i do WOT daily but never below 3k rpm, doing this for 20years+ with all my cars no problems, some people do WOT at 1k rpm that is bad to force engine to do work it cant :p
i dont go to redline since power is gone around 6k rpm...
dont worry doing WOT on stock cars guys, engine needs some leg stretching hehe, BUT! make sure engine is properly warmed up, engine is not warmed up moments after
water temperature shows half... oil need longer, and transmission also... so properly warm up the car and then enjoy, i have seen idiots to start turbocharged car at freezing degrees
and burnout to fuel cut off from parking lot, that is bad for sure, it is like going running or lifting weights without any stretching or warm up ;)
i still dont like the transmission in civic 1.5t manual, it is a slow shifter, it just doesnt like fast shifts
caspar21
2018 Civic Si
south central ontario
2018 Civic Si
uh ohh.. with sport pilot 4s on it i am using traction control in second and 3rd daily.
redline runs a couple times a week.
with 88k on the car tuned tsp1, i wonder when i am gonna hear the bang.. :doh:
if the track days didn't cause it and the autox racing didn't kill it then it ain't gonna happen anytime soon!
i find this platform very strong and reliable. the naysayers can sit and baby their rides all they want, i bought this car to enjoy.
jokacz
Upstate New York
09 Mini Cooper S, 19 SI Coupe
I've been kind of obsessed with intake valve carbon buildup in direct injected cars. According to wrenches who have to deal with this phenomenon, a steady diet of WOT (within reason) has been shown to minimize this buildup compared to cars that are driven very conservatively. Back in the day we used to call it an "Italian Tune Up" go out and put the spurs to it, blow the crud off the valves. I do it a few times a week. It's more fun than walnut shell blasting.
SDAlexander8
Steve
Indianapolis, IN
Continental extremecontact dws06 are awesome for grip. Just not great when thrown into turns too hard.
