Austin@Wunderladen Racing
- Austin
- Dec 6, 2021
- 46
- 1,106
- 2,327
- Chicago IL
- Website
- www.wunderladenracing.com
- 2018 FK7
Hey everyone, we’re excited to share that Kelford has recently started offering L15B cams! We’ve used Kelford cams in other cars and have always good results so needless to say we are excited to see them supporting the L15B engine too. For anyone not familiar, Kelford has a great track record making some of the best cams for popular import engines such as the 4G63, 2JZ, RB26, K series, etc. I’ve looked at the profiles they’re offering and the specs are much more in line with what the L15B wants compared to other aftermarket cams on the market so I expect the gains to be pretty epic!
Kelford currently offers 3 different cam profiles for the L15B:
"EZ" Drop In: The drop in profile is meant for use with the stock valve springs with a max redline of 7000RPM. Most of the gains will be in the mid and high RPM range. Lift and duration is 7.8mm/246° for the intake and 8.5mm/250° for the exhaust.
"A" Stage 1: The stage 1 profile is meant for use with higher flowing turbos, and like the drop in cams most of the gains will be in the mid and high RPM range. Lift and duration is 9.5mm/262° for the intake and 9.5mm/268° for the exhaust. The stage 1 profile requires upgraded valve springs, Kelford has a spring and retainer kit that is stable to 8500RPM.
"B" Stage 2: The stage 2 profile is meant for use with large turbos. Most of the gains will be in the high RPM range. Lift and duration is 11.2mm/268° for the intake and 10.7mm/272° for the exhaust. The stage 2 profile also requires an upgraded valve spring and can also be paired effectively with Kelford's spring and retainer kit that is stable to 8500RPM.
I’m sure many people will be asking what would be the best profile for their application and here are my thoughts. The drop in profile is best for anyone on a stock turbo and has no headwork done, stock valve springs etc. The stage 1 profile would be my recommendation for anyone who has put a mildly larger than the stock Si turbo on their car (W1, R365, GC, etc.) and upgraded valve springs. If you have an upgraded turbo but don’t want to change springs the drop in profile would still make for a solid improvement. The stage 2 profile I would only recommend for people running larger turbos than the ones mentioned for the stage 1, with a ported head and upgraded valve springs.
So, pricing. We are going to be doing a group buy for these, price will be contingent upon how many people buy in. The standard MSRP for these cams is $995, our group buy pricing will be as follows:
To sweeten the deal we’ll also be offering the same discount structure on Kelfords springs and valve stem seals for anyone who orders the Stage 1 or 2 profiles and would like those items. The spring package they are offering is specific for the L15B and uses the correct length spring seats to keep valvetrain geometry where it needs to be as well as uses a high quality spring steel for the springs. The valve stem seals they offer are made from viton and polyacrylic which is a high temp elastomer that can handle more heat than the stock seals, it’s a “while you’re in there” part to change. The seals go for $40 for a full set (intake and exhaust) and the springs and retainers sell for $595, if we reach the max discount those become $32 and $475 respectively.
We have been talking with Kelford about this for a bit now and are fairly ahead of the ball. Since these cams are so new Kelford hasn’t made any production batches yet. This means we will be getting these made and will be the first in the country (potentially the world) to get these cams. With that said, we are anticipating an early-mid September arrival for the order.
In order to get locked into the group buy I will need you to PM me with the following (copy and paste to keep it easy please):
Name:
Cam Profile:
Springs (yes/no):
Valve Stem Seals (yes/no):
Other than that we will be requiring a $150 nonrefundable deposit up front and the remainder will be due when we get them in from Kelford. I will keep the OP updated with who’s locked in so everyone can see what discount level it is sitting at. You’ll be able to lock into the group buy until August 11th.
Who's ready to make more power with their L15B?!
Edit: Cam specs vs stock per Kelford
- 5-10 people = 10% off ($895)
- 10-15 people = 15% off ($845)
- 15+ people = 20% off ($795)
Name:
Cam Profile:
Springs (yes/no):
