QuickJack TL or TLX?
tuxmonkey
R-00330
Houston, TX
'17 Civic Type R #330, '17 Jeep GC Overland
Anyone using the 5000 or 7000 TL or TLX? Based on measurements I don't think the TL will reach the lift points, so I assume the TLX is what I'd need.
NapalmEnema
I have the SLX and it works if you get the extensions - I don't know about the ones you listed but I believe the TLX would work but don't have hands on for it.
Here is the SLX and solution for it for reference -
https://www.civicx.com/forum/threads/brutal-quickjacks-wont-work-with-the-type-r.73180/#post-1115860
Aside from that LOVE the solution and use it all the time for all my cars. Easy setup easy teardown. Just be sure you add enough fluid when you set it up so you can get to the second lift point - first time I filled I didn't add enough fluid so couldn't go max extension...
cariboublue
Los Angeles, CA
2018 Civic Type R, 2004 Mazda 3
I second the SLX with extensions. Works great and super easy after the initial setup.
