Lust
- Michael
- Apr 17, 2018
- 16
- 1,411
- 1,777
- Bay Area
- 2019 Champ White Type R
- #226
I’m not entirely sure on the 2020 grills and compatibility so hopefully someone can chime in on that.Thanks Lust for your recommendations.
If like I was confirmed from others and a Hinda tech, we can swap out our bumpers to 2020 own to avail the larger grille. Case in point, I was going replace front bumper per an insurance claim thus the new 2020 bumpers to swap in on my ‘18 fk8
However like you mentioned fk8 could use an oil cooler I had played with idea before the new 2020 bumper came out, but please confirm with me if you will:
Will the 2020 grille fit to either bumper or do I need to get whole new 2020 bumper with grille - (Assuming like you touched eith a bigger grill opening for more air, which creates more drag which iron mistaken would explain why the bumper layout or bottom splitter is slightly different to compensate for any additional drag)
Then to avail any venting fit oil cooler, will that driver side vented panel fit on do we need while 2020 bumper?
Or is there not a slit opening on 2020 driver side to allow air in there? Will that suffice enough air for oil cooler?
As far as bigger down pipe, is it the rv6 performance but is there a catted version for those of us in Calif ?
Then assuming we the need to titanium wrap oil pan just not downpipe , correct?
As for oil, did I make a mistake on switching to amsoil but I forget which grade it was I think it was 5w-20 xl?
Meanwhile I’m a week or so awaiting on C&R radiator-street version
Thanks for your advice.
Forrest
RV6 does offer a high flow cat option which is what I have on my car.
Thermal barriers will certainly help.
5w-20 is fine but you might see increased start up wear with a higher winter weight. I’m having great success with Motul 300v 0w-20. You can experiment with 0w-30 as well.
