Overheating & What You Can Do To Stop It
Code Monkey
Rafal
Atlanta, GA
2019 Civic Type R
^ I floated that idea before and I think there are some guys who are tuned this way.
b2point0h
Brandon
2019 Civic Type R, 2006 v8 4x4 4Runner
Anybody had luck with detuning on higher amounts of ethanol? The boost would have to be heavily limited but the ignition advance could very well get it back to at least stock power levels, and ethanol is known to run cooler.
haltamer
Essex, UK
FK8 (UK / RHD!)
We want low pressure behind the radiator to pull air in from the front. Refer to smaller red arrows in the first drawing below.
As mentioned - That's part of what was done with the 2020 grille - Close that gap and increase the size of the main opening!
One thing that is nice about the aero of the FK8 is that the pressure on the front radiator (at higher speeds) is very well concentrated.
I'd argue for an increase in outlet venting at the rear of the engine bay (Giving additional negative pressure and increased throughput - The amount of heat from the wing rear vents is impressive after hard driving.
Has anyone tried opening up the wings futher to add venting?
This is the EU FK2:
Honda Civic 10th gen Overheating & What You Can Do To Stop It 1609135751492
The lower fender vent is completely aesthetic and closed, as is the upper wing vent (From the factory) - Though A few people have cut the vents in / fitted open trim pieces and have noted a large amount of heat evacuation from them.
Whilst the path isn't most direct, it'd sill lead to some evacuation - I'm not a walking wind tunnel, but by my best postulation I'd expect the flow (On the FK8 wing) to be quite conducive.
ApexEight
Anthony
Atlanta, GA, USA
2019 Honda Civic Type R
I'd imagine fender vents would help with lower IATs and not really affect ECTs. I think they're used more for aero purposes, but I'm not sure. Also, with the 2020 grille, isn't the area above the radiator on the passenger side still open? So even though the front of the area is now blocked off on the 2020 grille without the slit, air can still travel in through the main opening, and above the radiator through the path of least resistance, thus still allowing for the issue shadow is hypothesizing. I think creating a little block off plate for that area is still worth a shot. It's essentially more ducting for the radiator.
kilo959
J
Atlanta, Ga
2018 Civic Type R; 1995 Nissan Hardbody
Im surprised this thread is still going ?
Myself along with many others have figured out solutions already and we aren’t overheating anymore, so I don’t know why people keep bringing this up.
1. Get a better radiator. Wether that’s the C&R, or a Koyo with the Acuity hoses. (I went Koyo with hoses, but a friend of mine went C&R).
2. Tune. Ditch the stock tune for an ethanol based tune. (I went for e25 on 24psi. Friend went Flex base tune. Neither of us overheat)
Optional:
I went further and got a vented hood, high flow grill and oil cooler. Problem solved.
What HP are you pushing with this setup? I'm probably going this route just to not fuck with all the BS.
Waynegro372
Kyle
Tacoma/Seattle
A mule
So is there a reliable aftermarket cooling solution yet for those of us who don’t want to run ethanol?
Dave B
Dave
Whitby On Canada
Corvette Z06 (sold) 2020 CW
Have you read any of this thread? ???‍♂
Not all of us want (or can) run ethanol so the question is valid. Also the demands of some are different than others i.e do you have a tune or not? Bolt-ons or not? How many laps do you need to run at full power before you might accept having to cool off for a bit and what sort of ambient temps do you tend to run in?
MadMage
Dan
Arizona
2020 Type R
What's your use case? Tune? Mods? Ambient Temps? Acceptable operating temperature? Operating duration (how long do you want to run 'cool')? How quickly do you want to cool once you reach heat soak?
Edit: See Dave's comment above mine.
RepyT
Almost Stock ‘19 R on 255/35-19”
Dave
Destin, FL
2019 Civic Type R FK8, 2017 Lexus GX460 Luxury
Waynegro,
Are these laps clockwise or counterclockwise, above or below equator, same question except for artic circle, in Antarctica, driving, night or day, include driving that involves a Saturday overnight stay?
Gosh, getting thorough answers is hard with so many more variables.
Probably just a good idea to read all related posts and see what you think will help your unique situation, don’t get steamed, it’s all in good fun.
17RGuy
Texas
2017 Type R
Literally ALL of these questions or scenarios have been answered or discussed in this thread or any pertaining to @Lust C&R radiator and oil cooler threads. Searching and reading is a relic of the past apparently.
tinyman392
Marcus
Illinois
'18 Civic Type R (RR)
This thread is 18 pages long at this point, some of which are quite long while others don’t add much information. CivicX’ search function isn’t the best, especially if it’s keyword based, I’d wager more than ⅔ of the posts would be tagged in any of the keywords he searched for.
17RGuy
Texas
2017 Type R
I’ve reminisced on civicx before of getting banned or your hand slapped for not utilizing search functions on team-integra, ls1gto, and nasioc back in the early to mid-2000s. From what I see on this forum as well as my GM truck forum, 90%of new threads would not need to be created if members actually searched. Instead, we all need to be spoonfed?
