VitViper
- Apr 28, 2015
- 43
- 638
- 1,992
- United States
- Lots
Had a clutch designed months ago in anticipation of this 8)
Because I'm moee concerned about my daily driver obtaining 50mph while being daily driven than having the ability to change tunes. It's not a race car. The flexibility to go from the hondata tune you chose to run with opposed to stock is what would make me happy.Why? A tune with better timing, and better(leaner) A/F ratio should give better MPG than stock. MPG should only go down if you have a lead foot.
Yes.Are you saying the non-stock tune hurts performance, or mileage, or driveability in some way?
The Hondata tune performs better and yields better drivability though.Yes.
The Hondata tune does not return stock tune fuel economy.
They are in the works....we've already spoken with one of the major clutch brands about this.
Logic fail. If the new tune has better timing and better A/F ratio then it will get better MPG than stock. If you want to get 50MPG then you would WANT a good tune.B
If there was a tune that would give me better mpg then you're right. But unfortunately such a tune doesn't exist.Logic fail. If the new tune has better timing and better A/F ratio then it will get better MPG than stock. If you want to get 50MPG then you would WANT a good tune.
Hondata's basemaps don't alter the A/F targets or the timing maps. For the most part the basemaps just increase boost a little bit and that's it.Logic fail. If the new tune has better timing and better A/F ratio then it will get better MPG than stock. If you want to get 50MPG then you would WANT a good tune.
Well that's lame.Hondata's basemaps don't alter the A/F targets or the timing maps. For the most part the basemaps just increase boost a little bit and that's it.
The 6psi cvt tune DOES NOT remove the speed limiter. Not sure if Hondata is aware of this or not. Cuts out at 132. Same as stock.Thats also incorrect:
The base maps:
Timing maps are editable and tunable for fuel type.
- lean the WOT AF ratio
- Stabilize the power delivery by alteration to the knock air limit tables
- Remove the speed limit
- Give you full throttle shift to reduce boost lag
- Remap the Sport button for more boost
Fuel maps are editable and tunable for fuel type.
We are not supplying a custom tune. The supplied base A/F and timing maps are within Honda's standard operating parameters for the increased boost level.
Our maps are track tested for reliability.
did you set it up correctly? the stock cutoff is 124-5mph. make sure its set to MPH and not KPH. speed rpm limiter to 6000The 6psi cvt tune DOES NOT remove the speed limiter. Not sure if Hondata is aware of this or not. Cuts out at 132. Same as stock.
