Harlaquin
- May 7, 2017
- 179
- 1,780
- 1,354
- USA
- 2017 Type R and a beater ford focus
- #16
So basically its a screw up and typical corporate what's the absolute least we can do while we just wait for the cars that will die. All while letting people drive screwed up cars so we dont spend anything?You've got a DI mated with a low friction set of rings for fuel economy. They'll try to get the car to warm up a little quicker to help it vaporize. They're not going to institute it on all vehicles. The few failures that may occur in low risk areas will be cheaper to fix than to update the fleet. The bean counters have already assessed this I'm sure... as this has been coming for over a year.
The Xterra, Frontier and Pathfinders for years had defects where their radiators would break down internally and allow coolant and ATF to mix, and the higher pressure coolant would go into the transmission and kill them. They raised the warranty on all 3 vehicles to repair all those that died. The 100% solution was to go to a new version of the radiator and to replace all the vehicles earlier ATF that was found to be a smidge more reactive to the newer formulation.
It was just cheaper to repair the hundreds to few thousands that died. The chances of your vehicle dying were still pretty low, though many if us just bypassed the ATF side of the radiator and sacrificed the warm up/cooling since we had external coolers anyway. The nice thing about our problem is, so long as you let the car warm up during your drive, most should be fine. Short trips never allowing a warm up could be a problem.
I think over half of all the cars I've owned had some annoying flaw that could kill the car or just be a PITA. Leaking injectors in my Z31s... TCC solenoids in the Cadillac's, junky Honda transmission, worthless Honda VCM that never measurably improved MPGs but could wear the engine badly (it's also defeated now...), soft valves on my first Z32. Defective brake light sockets that died monthly in that Cavalier. The list goes on. No car is perfect.
