Lust
- Michael
- Apr 17, 2018
- 16
- 1,411
- 1,777
- Bay Area
- 2019 Champ White Type R
Your temps post intercooler will vary based on throttle input + ambient temp + speed. Your temps at the MAF shouldn't change nearly as much as the temps at the MAP.My understanding was IAT was the air coming into the air box, IAT2 is the air after the intercooler. It can climb because the engine starts to become heat soaked.
My IAT temps drop if I suck in a lot of air super quickly My IAT2 temps only drop if I am cruising for a while after I am heat soaked.
Let's say you're cruising at 65 MPH and your IAT is 20F above ambient, once you add initial throttle, you will see this temperature drop because you have more air traveling through the intercooler core. Temps will then start to rise for prolonged WOT pulls dependent on the cooling efficiency of your intercooler.
