Excessive white smoke from exhaust
Tury14
Arturo
2018 Honda Civic Si
I recently installed a catless downpipe and about 15 minutes after I noticed a lot of white smoke coming out from the exhaust when the car is idling. The smoke doesn’t smell like coolant, it smells like oil. Wondering if anyone has had this issue ?
dark_knight097
Daniel
Georgia
2017 Civic Si
Probably nothing serious. Burning oil would give a bluish-grey type of smoke.
Just monitor your oil and coolant levels for now if it doesnt go away.
Tury14
Arturo
2018 Honda Civic Si
I’ve been keeping an eye on them and they haven’t moved but the car is smoking like a train lol
Shankmeyster
AZ
23 Si
Post this in the exhaust section and maybe someone in there can figure it out.
Boostez
Samurai
Marlin
Fort Worth, Texas
2019 Civic Type-R; 03' Mitsubishi EVO; 2018 Polaris Slingshot SL-R
White smoke is coming from the engine. There is nothing else it can be. I'd do a compression check to make sure things are healthy engine-wise.
TheHorse13
Jefferson County, WV
2019 Civic LX
If your car is smoking like a train after two days, something is wrong. If you put the stock pipe back on there, does the smoking stop?
@that_1redcivic
Milly
Pittsburgh, PA
2020 Honda Civic Hatchback Sport (CVT)
That makes no sense lol... Has head gasket written all over it... What does your oil look like ?
Yeah buddy hate to be the bearer of bad news, but that sounds REALLY bad. Most likely a blown head gasket.
TheHorse13
2019 Civic LX
This sounds like the real issue. White smoke is usually coolant burning while blue is usually oil. The OP says no oil level change which lines up with coolant leaking into the combustion chamber. The down pipe may just be an unrelated part of the root cause.
OP, does your oil look like a McDonalds milk shake? That's a sure way to know if you have coolant leaking inside your motor from a blown head gasket.
Tury14
Arturo
2018 Honda Civic Si
Yeah, put it back on and it stopped smoking, cat must be burning it off before it exits
Tury14
Arturo
2018 Honda Civic Si
Haha no it doesn’t look like a McDonald’s milkshake. I thought coolant at first but didn’t see a change in coolant level and the oil looked fine.
