Bob_L
- Bob
- Feb 17, 2021
- 11
- 252
- 470
- Atlanta, GA
- 2021 Boost Blue Civic Type-R
Hi all,
So I took my car up to one of the local sponsored dyno events to see what numbers the car would make. While we were at it, I decided to datalog the session as well.
The numbers were a tad lower than I expected, but I don't know anyone else who only has "some" bolts-ons (let alone the same ones I have), and as a result I don't have any basis for comparison. It seems like most everyone in the area are either stock, or they jumped head first into FBO+.
For powertrain mods I'm running an RV6 catted downpipe, RV6 frontpipe, and PRL intercooler; everything else is stock (charge pipes, etc).
My tune is a Phearable Stage2 OTS tune. I've had one revision - the first version was when the car was fully stock; the currently installed revision is supposed to account for the dp/fp/intercooler. At my request, the tune is rpm limited to the factory default 7k (no 7200 for me).
The temp during the dyno session was 80 degrees F. All three pulls on the dyno were very close together so there was significant heat soak in the later two pulls.
Anyway, the first pull showed max of 351hp at 5910rpm and 373fp torque at 3760rpm.
In regards to the results, is such a wide range of rpm between max hp and max torque typical for the CTR? Also, given what I've read I was sort of expecting to be a bit higher with the bolt-ons and tune I have, but maybe that's the difference between reading about something and actually doing it. Have others had similar results?
Also, when I reviewed the datalogs (which I'll try to attach), I saw that when at or near max rpm, the "Knock Level (%)" got very high - 175 during the first pull, and close to that for the other two. I'm vaguely familiar with knock at a high level, but I don't know what "knock level percent" is. Is this something to be worried about?
Thanks for any insight that anyone can provide.
-bob
Edit: One last thing, not performance related - After the car was strapped down, we did the petal dance before starting the dyno runs as indicated on the fk8.wiki to fully disable VSA. We got the expected instrument results - blinking VSA light and forced into sport mode. However, when the session was over, the computer was still freaked out and gave the usual warnings about everything either disabled or having a problem, just like when flashing the ECU. So, even though we followed the steps and got confirmation from the car that VSA was fully off, it didn't seem to make any difference. As expected, it cleared up after a few miles driven and a couple restarts. Just a heads up for anybody who may be interested.
-bob
