A/C gurgling?
sniper
Toronto, ON, Canada
2016 Civic Coupe Touring
Anyone else hear gurgling noises when AC is on? I noticed it when I turned off the car yesterday, and figured it was just condensate collecting, but when I was on the phone today, I could hear it again. After the phone call, I turned off the music and turned off the AC - the gurgling stopped. Turned on AC, it came back, turned off AC, stopped.
I haven't spoken to my dealer yet, but will probably do so when I get a chance.
Syntek
Los Angeles, CA
2019 PWP Civic Si Sedan
Same here. First starting the car with the A/C and I hear a faint 'psssssst' sound which I know thats fairly normal. But even after the A/C is turned on for a good minute, I start hearing a faint gurgle as well. 26k~ miles now.
sniper
sniper
Toronto, ON, Canada
The sound is akin to when you're finishing a drink with a straw... and there's not enough liquid to fill the straw, so there's air/bubbling in the cup.
briq4
Brian
New Jersey, USA
2017 Civic Touring
same issue here, did any of you get it resolved? I don't think my A/C is all that cold, I have a 2010 TSX and it's much colder much quicker and it's got 100,000 more miles on it. Just wondering.
USMarineEJP
Boca Raton, Florida
Civic EX-L 2016
This just started happening to me as well. At 1st I thought it was the belt, but then I noticed it did not change with RPM. It’s really annoying. I’m at 23,000 miles. AC definitely took longer to get cold, and not as cold.
nicohockey9
Nick
2017 Honda Civic Sedan LX
Having the same issue.... Anyone figure out if this was normal or not?
shihkster1015
Vancouver
2016 Civic
I brought my car in for the gurgling noise. The dealer found a leak in my A/C system and had the condenser and low pressure line replaced.
nicohockey9
Nick
Went to the dealer, they said the sound was normal and they compared it to another civic which they said made the same sound. Also aperently checked the gas and drainage tube to make sure nothing was wrong; they said gas was full and no blocks for drainage.
My AC is working but this sound is fairly annoying. The car definitely was not doing this when I first got it. Wonder if my AC will begin having issues eventually.
SCOPESYS
Geoff
MD
Went to the dealer, they said the sound was normal and they compared it to another civic which they said made the same sound. Also apparently checked the gas and drainage tube to make sure nothing was wrong; they said gas was full and no blocks for drainage.
My experience with Dealer's Techs and most independent garages, is that the mechanics really do not have a clue about correctly diagnosing, maintaining, or charging AC systems. They just know enough to be dangerous !! Sure, they can throw some more refrigerate into the unit (and are really good at throwing DYE in - to clog it up), but when it comes to fixing more complex problem, or optimizing the cooling process, they either don't know how, or their hourly rate is so high that they cannot do the work correctly, because the time/cost would be unacceptable to the customer.
My older car had had AC issues for year, It never blew really cold, like it did when new.
Had a number of "CAR" places look at it, and they all either did not make it better, and some even made it worse.
Finally, I got an Commercial A/C Tech (Friend ) to look at it. He removed (reclaimed) the refrigerant, flushed out all the old gumming up dye etc, replaced a few inexpensive parts, tested for Vacuum (overnight), and then recharged it with new refrigerant and oil.
Then he went on to optimize it's cooling, by adjusting the refrigerant level to that which produced the coldest air output from the vents, gaining about an extra 10-15 deg F drop over what the the manufacture's labeled recharge amount gave.
Now it almost blows TOO Cold !! If the sun is not beating down on the car in the summer, the cold air can get so cold it is almost PAINFUL if the fan is at full speed...
a nice state to be in-- More than sufficient cooling , rather than not enough.
shihkster1015
Vancouver
2016 Civic
UPDATE from the dealer replacing the condenser and low pressure line
the sound is back. trip back to the dealer again
fenix-silver
Central PA
2019 Si
Curious if anyone who had this issue ever found a resolution?
Shane_pcs
Shane
Prosper, TX
2021 SGP Sport Touring, 2016 Honda Civic Touring
my 2016 touring sedan has always done this. Never had any issues with cold A/C or any freon leak. I suspect it's normal. My new 2021 sport touring also does it occassionally.
fenix-silver
Central PA
2019 Si
I did some additional searching, not necessarily related to the 10th gen, and I've come to this conclusion as well. Just sounds like it's a normal A/C noise in some vehicles.
DRUSA
Dan
Palm Springs, CA
2023 Civic Type R 2000 Honda S2000
A slight "HISSSSSSS" sound when first starting the A/C system is normal, it should only last about 2 or 3 seconds. This noise is just typical of the 10th gen system, some older Honda systems do it as well. The A/C system works by creating a pressure differential using the expansion valve behind the dash, you are hearing the first actions of the pressure differential, similar to when you open a soda bottle the first time. Totally normal. If it continues to hiss after that initial start, you have a problem. If it hisses several times, hisses every few minutes, or continuously hisses non-stop, these are symptoms of a low refrigerant charge and a leak in the system.
Gurgling sounds are typically water in the evaporator box due to a plugged drainage hose or air in the engine coolant system, translating to bubbles in the heater core behind the dash.
