- Mitch
- Oct 27, 2015
- 334
- 17,030
- 24,816
- USA
- Website
- www.civicx.com
- 2017 Cosmic Blue EX-L Sedan
- Vehicle Showcase
- 2
Let's take a look at the 40 major failures in my tuned reliability thread with some cliff notes from me. How concerned should you be that your tuned car will fail?
1. A car had a failed CVT (replaced under warranty). Possible factory defect
2. A car had a blown head gasket on a base +9 Hondata tune. Concerning
3. A car blew a CVT pushing the car hard with an existing emissions problem. Neglect
4. A car blew an engine running an E35/meth setup. Super high output tune
5. A car blew an engine when the owner mistakenly used non-race gas with a tune designed specifically for race gas. User error
6. An owner had major failures on a used car he purchased. Car was possibly abused by prior owner
7. An owner admitted he abused his car and destroyed his engine. Abuse
8. A non-Si owner blew his engine on a Stage 2 Powermetric flex fuel tune w/full bolt ons. Unknown, very rarely installed tune
9. An owner had his CVT replaced under warranty (high power ethanol tune); the new CVT has been trouble free for 70,000+ tuned miles. Possible factory defect
10. A car threw a rod under "iffy" circumstances. Owner loaned his car out and it was abused
11. An owner destroyed his CVT after some track time in 100° weather. Race track use
12. A car had a bent connecting rod but there were many factors (neglect) beyond the tune. Neglect; had hydrolock and ignored engine knock
13. An Si blew two OEM head gaskets (finally replaced with a better aftermarket gasket). Concerning; FBO+flex tuned
14. A car bent a rod while doing WOT datalogging for a custom remote tune (had run meth for a short time as well). Concerning; hatchback
15. A car blew a CVT after serious neglect/abuse with numerous brake launches and burnouts. Abuse
16. An Si blew a transmission running a high power flex fuel tune (full bolt ons). Concerning
17. A hatch bent rods, had bearing material in the oil and CVT issues. Concerning
18. An Si blew the head gasket and lifted the head after 14,000 aggressively driven tuned miles. Concerning
19. A Type R had overheating issues; blew the head gasket and the top piston ring scored the cylinder wall; engine replaced. Track car
20. A car had a failed CVT running a base tune on a stock setup (replaced under warranty). Possible factory defect
21. A car bent a rod after filling up with low octane gas (sold as high octane) in Egypt. Odd, one off situation
22. A car bent a rod on a high output custom tune during a WOT pull. Another hatchback rod failure, concerning
23. A car had a catastrophic engine failure when a tuner bumped up low end torque too far. Poorly set up custom tune
24. A car (a 1.5T hatch) had an engine failure where octane booster possibly contributed. Octane booster is a no no
25. A hatch blew an engine after adding too much octane booster to the tank. Same as above
26. An Si blew a head gasket running a high power flex fuel tune. Concerning; flex fuel again... is this a pattern?
27. A custom tuned 2.0NA had a CVT failure. Unknown; driving style or defect?
28. An Si failed when the engine seized up due to a likely oil pump failure. Are oil pump issues a thing?
29. A Non-Si engine was destroyed when the intake camshaft snapped possibly due to a defective oil pump. Same question as above
30. A hatchback bent a rod running a base tune with no bolt ons. Concerning
31. An Si needed a transmission replacement due to a bearing failure (replaced under warranty). Possible factory defect
32. An Si had damaged engine bearings likely due to a failed oil pump. Oil pump again
33. A car's engine had a spun rod bearing. Rare failure, factory defect? Car wasn't abused
34. An Si owner blew his transmission after admittedly beating on his car long term. Abuse
35. An Si blew a head gasket on an OTS flex fuel tune. Concerning; flex fuel again
36. An Si blew it's transmission after many hard driven miles on a high power tune. Honestly, not a shocker
37. A Non-Si owner had a failed CVT on a car he purchased used. We don't know if the prior owner abused the car
38. A hatchback owner blew his engine on a +6 Hondata base tune. Concerning
39. A CTR track car suffered a blown head gasket and scored cylinder walls. Race track use
40. An aggressively driven Si (on an OTS ethanol tune) had a transmission failure. Flex fuel strikes again or factory defect?
Here are my takeways from all of this keeping in mind my tune reliability study is a work in progress.
I need all tuned owners to pitch in there by adding their car and adding new update posts. It's all about studying things as the tuned miles ramp up.
Head gaskets are a legitimate concern. But, so far, most failures have been limited to high power flex fuel tunes/FBO. That's not to say head gaskets aren't an issue but a guy on an OTS tune with little to no bolt ons, should fare OK on that front.
Don't touch octane booster with a 10 foot pole.
Type R's are rock solid. The only failures were two track cars.
Are oil pump issues something we need to be concerned with?
Weaker hatch rods are a thing.
My overall takeaway is that someone running a mild OTS tune, using the proper octane and maintaining their car, should be fine for the most part avoiding a major failure. Hatchbacks included. But once you add more bolt ons, up the power and/or abuse/neglect things, the failure rate goes up considerably.
