AEFXC
- Aug 27, 2020
- 4
- 3
- USA
- 2016 Civic Touring Coupe
2016 Honda Civic Touring Coupe with 19k miles - 1.5L engine with CVT.
Conducted an oil change myself. Drained just over 3.5L of fluid from the engine and oil filter. Filled new Bosch 3323 oil filter with 0W-20, installed it. Added 3.25L oil to engine - I am certain of this. Dipstick ran high, like REALLY high - maybe 2.5 inches up the metal above the plastic piece. Checked this both cold and using the owner's manual prescribed procedure of idling for a few minutes and then waiting three minutes, same result. I was very perplexed by this and honestly indignant, and my parking spot is on slight a incline with the engine low and trunk high, so I pulled around to the front of the building (~300 feet). Engine started revving freely with only a small amount of power making it to the drivetrain, ended up with no power to the drivetrain out in front of the building. The engine itself ran perfectly smoothly, normal idle, revs sounded perfectly smooth.
Same dipstick reading on level ground maybe 2" up the metal. I made several attempts to drain oil from the dipstick tube using a narrow fuel hose, using this thread as guidance: https://www.civicx.com/forum/threads/practicle-oil-dilution-measurement.33511/ . I never was able to pass a 3/16 OD fuel hose fully through the dipstick tube or able to pull anything up this way. So I jacked the car up again and attempted to drain some oil via the oil drain plug. Something on the order of 0.25L came out and after that nothing came out. I removed the oil cap on top of the engine, removed the dipstick. Absolutely nothing further came out of that engine from the oil drain plug, no heavy pour and a stop - just a gentle trickle from the start that tapered off into nothing. Dropped the car back down and checked the dipstick, still got just about the same reading on the dipstick - now maybe 1.5" above the plastic piece, honestly not certain it changed at all. Tried to at least get it back into my parking space, but there was zero power going to the transmission and the vehicle threw up a transmission error. The engine itself still sounded normal and smooth as butter. Made a second attempt to drain oil from the oil pan, absolutely nothing further came out. I removed and emptied the oil filter and put it back on, still no change in dipstick oil reading or transmission status.
Last oil change was 1yr ago when an oil change was performed by honda service techs per that recall that went out. The 3.5L I originally drained out looked a bit more like honey than the black oil I'm used to draining. The ~0.5L I drained later on was black with no observable color tint or debris. Never had a single maintenance issue with the vehicle until now, beyond the dang infotainment system. I'm having a bit of deja vu like I had a similar albeit transient issue when doing a previous oil change myself, but that was at least 2 years ago and I don't even remember if it even happened.
I am the most perplexed person on the planet right now and my car is completely inoperative. Any thoughts, suggestions or ideas would be very welcome.
