Froz3nTundra
I'm a little confused, were you accelerating and shifting from 2nd->3rd? If so why were you letting off the gas? You mention it was AFTER a shift into second?Although I couldn't capture audio, I can be a little more specific being it just happened this morning. I was in 2nd about to shift into 3rd around 3700-4000 rpms as I completed the shift and began to let off the gas to slow down I heard that same whining sound again. It was only after that shift into second did this noise start occurring with no gas applied in 3rd gear. The feel of my clutch during that shift into 3rd feels like a great amount of pressure is being exerted on the clutch as I try to release. I'm not sure if that's just because my rpms are rather high in a low gear. I hope that all makes sense and will clarify if need be.
If you could clarify if you were downshifting from 3rd->2nd and engine breaking or if you were accelerating from 2nd->3rd. If you were accelerating usually you get back on the gas as you let off the clutch.
Also, if you are downshifting are you rev matching? If you are going from 3rd at 2500rpm to 2nd at 4k rpms you should blip the throttle after the clutch is depressed to match the revs. Sometimes this is hard unless you practice heal toe shifting if you are in traffic but it's generally good practice if you have the ability to rev match as it will reduce wear on synchro's clutch etc.
