please HELP!! p0087 code
cota
jaiden
New Jersey
2018 Civic Si
2018 civic si, 48k miles
ktuner, intake , intercooler
i was just driving and i suddenly had p0087 code. i pulled over immediately and all my cel started popping up. after about 10 mins my fuel trims shot to -17% and my bank 2 fuel trims are extremely rich. what do i do???
Honda Civic 10th gen please HELP!! p0087 code F8C7DD32-DCF3-44E6-BC1C-FAA373AB8B45
Honda Civic 10th gen please HELP!! p0087 code 0BCB659F-BAEB-4888-9D38-B633C8BFA22B
First off relax a bit. Not sure why you're looking at bank 2 trims. Those only apply to V6 engine, not ours. And your LTFT1 is 0. That -17 STFT isn't that unusual if it's just a blip here and there. IATs are kind of high. But you can't tell much from a screenshot versus an actual datalog.
As far as that code, I've seen it be fuel pump related and I've seen people get it once and never see it again (glitch).
cota
cota
jaiden
New Jersey
2018 Civic Si
okay, its just im far from home and i dont have my laptop on me so i cant check my logs. thanks tho. its iats are high bc its really hot rn and idle. any suggestions?
That_slow_civicfc1
2017 civic Si ,2020 civic Si,2019 Si
turn the car off wait a bit then back on and drive a bit. happened once after a night of fun driving. did you touch the obd2 connection cable? that'll do it
cota
cota
jaiden
New Jersey
2018 Civic Si
i ended up just driving under 2k rpm for 20 miles back home. i had to drive 6th gear at like 40mph. i still have cel. i contacted Eman and he says its the fuel pump. but he also says i should just replace the whole fuel system for a fk8 one. thank you guys!!
cota
cota
jaiden
New Jersey
2018 Civic Si
i mean like i literally tapped the throttle, probably less than 10% tps. i gained a lot of fuel economy from it LOL. if i tried slamming the throttle it would just cut because it would reach 2k rpm immediately. starting on a hill was difficult too bc i couldn't even rev as much to get the car moving without it feeling like it's going to stall. technically it's still driveable, but the fuel system could completely fail at sooner or later. i'm getting it fixed on friday i hope
That_slow_civicfc1
no I mean use the the type R fuel system. if that's the case I could have had all my fueling issues solved months ago. I've had my car max out for a while now.
bbeem
Ben
Iowa
That had me lol. I didn't know you could use the fk8 fuel system. I also didn't realize op drove 20 miles in limp mode.😂 When I went into limp mode I couldn't break 10%tps so couldn't get above like 25 or 30mph in 3rd iirc.
cota
cota
jaiden
New Jersey
2018 Civic Si
update: i had a shop that replaced my intank fuel pump with dw300 fuel pump. issue persists… my next guess is the high pressure fuel pump. any ideas?
it runs very lean, but once it goes into limp mode, the fuel trims are -10 to 0
the crank is still about 3 seconds. when before it was instant
That_slow_civicfc1
every thing cost about the same so I guess do the HPFP then if you still have problems, do the injectors. weird youre having fueling issues only running 93. the system shouldn't be that close to maxing out. mines been maxed for about a year now thankfully no issues
cota
cota
jaiden
New Jersey
2018 Civic Si
idk, i do remember that when i first tuned on ktuner with intake and intercooler, i felt like i was pushing quite a lot of power. gradually i did notice a decline in power over time but i thought it was just the weather. i also noticed inconsistent patterns with throttle response so i would put injector cleaner and what not. i heavily convinced myself that it was the intank pump but i think i steered myself away from what i initially thought was the hpfp. i ordered it off prl already, thank you
cota
cota
jaiden
New Jersey
2018 Civic Si
i used lucas before, and about 1 month ago(3tanks ago) royal purple max cleaner
cota
cota
jaiden
New Jersey
2018 Civic Si
BUMP
I have p0087 code again, but i previously had this code fixed by replacing the Intank fuel pump first(didn’t work), then the HPFP(worked). Symptoms are different
Before: Long crank but starts, driveable but limp mode(wont rev past 3k)
Now: Long crank, sometimes starts but then stalls. will rev as high as i want as long as there’s power(fuel/air/spark) and sometimes it wont rev up if i press on the gas
Now i have to get it towed bc it’s just going to stall after driving 50 feet…
