Do you know which downpipe uses the heat shield ? Or couldn’t you wrap the p2r with heat wrap ?Since it doesn't use the heat shields I'd shy away from it.
Wrap is not bad. But it's not the best. That and coatings are getting better. The best fix is to move the intake pipe but who knows when someone will engineer that.Do you know which downpipe uses the heat shield ? Or couldn’t you wrap the p2r with heat wrap ?
Does anyone know how good is the P2R downpipe?
Putting a blanket or heat wrapping on the downpipe will have a positive effect on intake temperatures and help you stay at high levels of boost during spirited driving. That is a fact.Just FYI heat wrap is fine. Doesnt change intake temperatures. Buy what you like based on facts not opinions.
I just want it to know if it was a good downpipe before using it on my type r . I also want it to see how the p2r downpipe compares to other downpipe in the market like the PRL and more. 2 people told me it was a good downpipe and one person told me he wouldn’t use it because it didn’t use the heat shield.P2R makes very quality parts. I had their FP and Exhaust on my first Type R.
What are your concerns?
I actually know who the owner is.
I said to wrap it... the flimsy heat shield doesn't stop much.Putting a blanket or heat wrapping on the downpipe will have a positive effect on intake temperatures and help you stay at high levels of boost during spirited driving. That is a fact.
Yeah, the heat shields are meh. Better than nothing, but meh.I said to wrap it... the flimsy heat shield doesn't stop much.
Thank you so much for the feed back I really appreciate it. What kind of other mods you got on your type r.I know many people down here in South Florida who run it. I also know their service is amazing. I currently run PRL But..... I'd gladly run P2R in a heart beat.
The heat shield is not needed if you ceramic coat or heat wrap the DP..... I do not use the heat shield on the PRL DP and it can support it....
Hey OP Ive been running the P2R downpipe wrapped for 46,000 miles now. No issues.Does anyone know how good is the P2R downpipe?
Who use's the heat shield? That is what wrap is for.Since it doesn't use the heat shields I'd shy away from it.
