kytos
- Marcos
- Apr 18, 2018
- 7
- 604
- 419
- Madrid - Spain
- Website
- www.instagram.com
- CIVIC SPORT 1.5t 2017 EUDM
Hi,
I have an intermiternt issue with my fuel trims. It started since september 2020, one night I noticed partial loss of power and when I looked at tunerview AFR was down to 8 and trims were at -25, parked at the nearest safe place and checked every vacuum line, everything was aparently ok. Since then trims have been hovering between -7 to -15, same issue happened again 2 times and finally today I datalogged (stock tune) since it happened yesterday again and threw a P0172 while datalogging.
Thing I've done trying to solve/diagnose this:
- Check vacuum lines (cutting flow by hand and checking stft changes)
- Check charge pipes for leaks
- changed PCV valve (another issue)
- flashed to stock tune
- moved the MAF sensor cables to see if it is a wiring issue
And I don't know what else to do. MAF readings doesn't seem bad. I'm thinking on leaking injectors but I'm not sure right now what could be causing this.
Attached are the datalogs, too rich is when the ECU threw the P0172 code and the other one is after erasing the code and restart the engine . Any guess?
