ayau
Per Hondata, the factory map is tuned with 0% ethanol. US gas typically has 10%, so that would already throw off the fuel trims by a little. That's why Hondata has a map that adjusts for the 10% ethanol.
Your car is most likely running in closed loop majority of the time (cruising, slow to medium accelerations, etc). Closed loop means that the car will automatically adjust the fuel trims so that you still hit 14.7 AFR.
In open loop (WOT), you may running slightly rich or lean, but I don't believe there will be any longterm negative effects. The ecu should throw a check engine light if something was really wrong.
I wouldn't be too concerned and just continue to monitor the fuel trims over the next couple fill ups.
