Intake manifold developement
Scarlet
Shawn
Caledonia, WI
2001 Civic LX Sedan - 1998 Civic Hatch - TBD Turbo Something - 2014 Honda Ruckus - 2017 Civic Si Coupe
I'm just here to ask where the runners are.
I've emailed Skunk2 asking if they are going to be developing a intake manifold for the 10th gen, have't heard back yet! I assume they would be the first likely..
kshawn
Matthew
Maine
2017 Civic SI
Not bad for scanner and converting to bitmap. Clean the edges up a bit and get a metal prototype cut
Question. How hard do you think it would be to drill and tap that. For a 4 port meth injection
turbociv910
turbociv910
taylor
wilmington nc
very easy with the spacer i just had made. can drill each runner.. i had it made out of wood to verifiy fitment then prototype in metal.
turbociv910
turbociv910
taylor
wilmington nc
they are not pictured.. the stock intake flange was bolted up to verify the hole locations and ports looked good from the drawing.. its a 2-3" spacer that is in between the head and plate..you should know a huge plate like that isnt going to just bolt to the cylinder head :doh:
kshawn
Matthew
Maine
2017 Civic SI
I would totally take a metal spacer ;) following intently
Benster
Ben
Nova Scotia, Canada
2019 Civic HB Sport 6MT
long runners for all motor will only give you low/mid range power. It depends on a lot of things like runner size, taper, etc but as a rule of thumb, runner length depends on where in the powerband you want the power. That's why some motors have a dual intake, long runners for low/mid range and a butterfly valve opens up to let air through the short side for full throttle and high rpm.
turbociv910
turbociv910
taylor
wilmington nc
well here it is.
Fuel Fitting is still a banjo, Id like to make it a metric/an fitting and route the fuel line under the manifold (cleaner) but i didn't have a straight fitting in my box and didn't want to wait. I feel the banjo bolt is a real bottle neck for the high horse power guys and is over looked. The whole 1/4 fuel line needs to go to at least a 5/16 or 3/8. The pump outlet is probably a 1/4 so its a lost cause for now.
I have to make changes the throttle body adapter and add o ring grove for gasket but nothing i cant fix. I made it on too thin of a piece of material and had to make it in my garage on my manual mill using a thicker plate to clear the throttle body motor.
What you cant keep- lower rail sound insulation and sensor cover bracket (above alternator). Throttle body wiring harness bracket that bolts on the oem intake and fuel pump.
Plenum volume is roughly double (guessing) and it feels faster on the butt dyno. My car is all stock SI just with a 23 psi tune.. will get it on the rollers this week sometime..
Needs- K series plenum so you dont need a ait block off of the older b d h f engines.. bybass valve (bov) solenoid bracket.
Honda Civic 10th gen Intake manifold developement Photo Sep 15, 6 32 34 PM
Honda Civic 10th gen Intake manifold developement Photo Sep 14, 5 40 49 PM
Honda Civic 10th gen Intake manifold developement Photo Sep 15, 2 02 45 PM
Honda Civic 10th gen Intake manifold developement Photo Sep 15, 10 02 15 AM
Honda Civic 10th gen Intake manifold developement Photo Sep 15, 10 04 22 AM
Honda Civic 10th gen Intake manifold developement Photo Sep 15, 10 09 36 AM
Honda Civic 10th gen Intake manifold developement Photo Sep 15, 10 10 17 AM
Honda Civic 10th gen Intake manifold developement Photo Sep 15, 6 11 04 PM
Honda Civic 10th gen Intake manifold developement Photo Sep 15, 6 11 10 PM
_HatchED_
Eddie
South Carolina
2019 Hatchback Sport 6mt
well here it is.
Great progress!
Any plans to compare the OEM and this manifold on the Dyno? Would be interesting too see where the added plenum size helps the hp and tq through the room range.
turbociv910
turbociv910
taylor
wilmington nc
Great progress!
just going to dyno it and see how the graph looks
JC671
Youtube: JaySi.671
JC
GU
'17 Civic SI, '90 GTR, '10 370z, '90 Mr2 Turbo
Subscribed
PowerPerLiter
Specific Output
Midwest
well here it is.
Killer work!
JKessler
Jordan
Columbus, OH
2017 Civic EXT
Rad work dude! Super impressed with your craftsmanship.
turbociv910
turbociv910
taylor
wilmington nc
Any update since the last post?
i posted on facebook.. went to the dyno and had problems. made 217 with the one pull i got. still having tc issues with sport mode
swah_fk7
Regamaster King
Martin
Miami, FL
Turn Traction Control / VSA completely off using the pedal dance sequence. That error will no longer occur.
