No, it actually starts when I'm engine braking. It's almost like if I step outside of the CVT's preferred gear ratio for too long, it starts whining as if it's upset.It sounds like a temu supercharger.
About to supercharge your CVT to death
Otherwise yeah change the fluid.
Quick question to add. Since you said it only happens in S mode. Is it only when you step on the pedal?
It usually doesn't do it in automatic S mode, but if I have been driving in manual S and switch over to automatic S, the whine will persist quietly. I have only used automatic S a few times, so I'll drive it like that for a little bit this evening and see how that goes.This may seem strange but I was wondering does it do this in automatic S mode too or just in manual S mode like u do?
And agreed, I'm usually at 80-90 mph and there is never a noise in drive, but maybe it's more to do with gear ratio and less with actual RPMsI mean right, I know S mode is, what, maybe 600 rpm higher at any given throttle position.
But think about it. If he's driving in D and he doesn't hear the noise at ANY rpm, even after long drives at high rpm isn't that strange?
I don't know what that sound is. What I can say though (if it helps for comparison to narrow it down) is that my vehicle is not making that sound. Done nothing special to the transmission except daily driving and changing the fluid every 40,000kms.This video is only of the whine, it only becomes this loud and obnoxious after driving for maybe 10 mins or so. Mostly in low gears. There's a whistle sound too when I come to a stop, but that's hard to get on video, very quiet and hard for a microphone to pick up since it's really high pitched.
I'd listen with headphones or at high volume, since my mic prefers to pick up the lower pitched road noise or engine noise.
Does yours have paddle shifters? This only happens when using paddle shifters.I don't know what that sound is. What I can say though (if it helps for comparison to narrow it down) is that my vehicle is not making that sound. Done nothing special to the transmission except daily driving and changing the fluid every 40,000kms.
How often do you do fluid changes and what kind of fluid do you use? Are you a 1.5t or a 2.0? Have you tried using the paddle shifters for longer than 10 minutes while engine braking in gear when coming to a stop and revving up to 3k or 3.5k before up shifting?Yes, it's got paddle shifters and 125,000kms
Fluid changes for me are every 40,000kms with HCF-2 CVT Transmission fluid on a 1.5t. Yeah i've used the paddle shifters and S mode going down steep hills and pretty sure that sound isn't there.How often do you do fluid changes and what kind of fluid do you use? Are you a 1.5t or a 2.0? Have you tried using the paddle shifters for longer than 10 minutes while engine braking in gear when coming to a stop and revving up to 3k or 3.5k before up shifting?
