I think the rubber gasket clears the hole on the left side of the 3.5 Accord throttle body and will seal. If not which orientation would seal? I’m going to have to wait till I see my tuner to make the adjustments on the Motec M142 after I install it there. I had put it on but on the car isn’t drivable.
I've learned theres an adjusting screw next to the black motor cover, when i first installed this i got codes for throttle sensor out of range, my limit for idle was between .4 and .7 volts and when installed it was reading .9 volts. the adjustment screw will have to be loosened out to correct throttle valve angle and voltage. anyone else install theirs with pre and post dyno results?
