Are the stock tires really this noisy???
Nitori
Arizona
2019 Civic Si Sedan, 2016 Toyota Tacoma
Hi all, first post here, just took home a 2019 Civic Si Sedan in Aegean Blue... 77 miles on it as of right now! :D
I am kind of concerned by the amount of tire noise I am getting, I don't recall it being so loud on my test drive but dang these things are howlers!
And that's saying something coming from a person whose other garage spot is taken by a Toyota Tacoma with all terrain tires on it...
So does it calm down a little after the tires wear in a bit, or is there potentially some other issue afoot?
Roadcone
Kyle
Upstate, SC
'14 FR-S + '19 CTR
what tires are they? check your tire pressures and make sure everything is where its supposed to be. also visually inspect them and make sure they arent showing any sort of crazy wear from a bad alignment.
TypeSiR
On a Twisty Road
1.5T Civic, Fit, MX-5, CTR
Yes, the Si’s all-season Goodyear Eagle Sport tires are notoriously loud. As already mentioned, check proper tire pressure (32-33 psi).
ski-line900
Kevin
The 18" tires on the hatchback are so noisy. Terrible.
Honestly the OEM tires are loud, but something else is a factor. The rear of the car has very little sound insulation.
Weeks
Evan
Dawsonville, GA
2019 Civic Si
I had been wondering this, too, but honestly I've just grown used to it over the last couple of weeks. I wonder if there are some other tires out there that wouldn't be as noisy.
PhilF
Phil
South Central Pennsylvania
2020 CRV EX-L Platinum White Pearl/Ivory, 2020 CRV EX-L Crystal Black Pearl/Grey
I am running Michelin Primacy Tours on my Touring Coupe (235/40/18) they have proven quiet so far, have 5400 miles on them, I've also read the the Vredestiens are also quiet as well.
Nitori
Nitori
Arizona
With only 77 (now like 140 something) miles on the car that'd have to be an egregious alignment issue...
But yeah, the pressure was the main issue. The incredibly talented service monkeys decided 49-50 PSI was a good place to start. :thumbsdown:
Not too thrilled with the service department so far- no to mention there's other issues like the aftermarket alarm they said was removed is clearly still dangling under the dash... but I won't shit up the tires thread for that. :bat:
Regardless, thanks guys!
Benster
Ben
Nova Scotia, Canada
2019 Civic HB Sport 6MT
Had the same issue with my car from the dealer, they left them at the 51+psi that it had when it got off-loaded. Kinda scary to think that their checklist doesn't include check tire pressure prior to releasing a vehicle. To their benefit though, I gave them 3 hours to get the car prepped, undercoated and rust proofed before I left so I figured some things would not get looked at.
wdubose05
William
Fort worth,TX
2018 Civic Si Sedan
I finally had enough with the factory Goodyear Eagle Sports. I switched over to Michelin Pilot Sport A/S 3+ and while it's not a night and day difference in terms of noise it is noticeably more subdued. I hear less tires/road and more engine now.
I was never confident in the Goodyears in wet conditions, they would hydroplane bad. The Michelin's have exceeded my expectations in terms of noise & dry/wet traction.
I also looked at Continental DWS06 but felt more comfortable with the Michelin brand.
CTRx
2019 Civic
No concerns with the OEM tires yet for me in Canada.
JohnnyL
2019 Civic Coupe EX
19 EX coupe with Continentals and it's no concern at all. Great tires. I will say it depends a lot on the road surface itself. Fairly new surface and they are super quiet.
Greyhouse
Robert
2017 sport touring
You know when I typed in this issue this site came up ,I thought it was just my 17 sport touring hatchback making that howling noise,on some roads it almost hurts my ears,I’m hoping that Honda added more insulation to it’s later models as this is unacceptable hopefully stickier tires will help my situation
jayy_swish
Jay
Stickier tires will make it worse lol, and on top of that give it a rougher ride because it’s more planted to the road.. what you need is sound deadening. The conti. stock tires weren’t bad for me, but then again I don’t care much for road noise or rough rides. If I’m planted with summer tires and can corner aggressively I’m happy. Plus how else am I going to hear that exhaust with a lot of sound deadening :beer:
